跳转到主内容
加入维修社区 - 创建账户
HTC EVO 是一款由 HTC 推出的智能手机,搭载 1 GHz Snapdragon 处理器并运行 Android 操作系统。
Screen installation adhesive and procedure?
saw your teardown of the HTC EVO and since some of the EVO owners are experiencing screen separation issues..
Can you create a procedure with type of adhesive used to install a new glass screen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Thank you for the guide, but I was looking for a adhesive recommendation and a technique for holding the glass down level under the bezel.
完成的
I also what to know,it looks like a gasket the that holds it down.
完成的
添加一条评论
10个答案
最有帮助的答案
That would be right here.
这个答案有帮助吗?
得分 3
2条评论:
Glad to see those guides are coming in handy :)
完成的
I have to say I was amazed to see them already there, the other day they weren't and I was directing people to the teardown. Good job on the quick work!
完成的
添加一条评论
此回答最初是针对另一个问题
Just be careful, I was kind of understanding that it is a display issue with the glass seperating, but I could be wrong. Why else did they stop using the one display and go to another as reported today on several sites like http://www.phonearena.com/htmls/New-EVO-...
Goog luck, I am returning and getting another one before my 30 days is up at Best Buy.
这个答案有帮助吗?
得分 2
1条评论:
sorry you must not have understood me. I have 002, and I do not want 003. I want to know what glue is the best to use to glue down the screen on the phone I have. I cant get nor do I want an exchange. I am not scared to open the phone by any means. thanks for your response though. To answer your question htc stopped using the more expensive display to go with the cheaper one. The display has nothing to do with the screen separating from the phone its the faulty glue which for me is an easy fix if I know what kind to use.
完成的
添加一条评论
此回答最初是针对另一个问题
Actually, I recently had to replace my evo with a newer one. I much prefer the newer screen. I believe the more "expensive" display you are referring to was the novatek screens, where as the "cheaper" screens are the epsons. In my opinion, while not quite as bright as the nova screens, the epson screens produce a much better color quality. For me, that is preferable in a screen. Others prefer the brighter nova which also seem to have a SLIGHT purply hue to the coloring.
Oh and just an FYI, your hardware info number eg. 002 and 003, does NOT automatically tell you which screen you have. There have been both nova and epson screens since launch with both screens being found on 002 and 003 revisions. Just check the android forums or xda. I won't go into how to tell which you have here, but there are plenty of ways to tell at the other sites.
这个答案有帮助吗?
得分 1
添加一条评论
此回答最初是针对另一个问题
Use Jet glue slow jell. It isn't super slow but gives you a little time before it sets. That is, 15 seconds or so. As far as removing the old adhesive, a hair dryer should suffice.
这个答案有帮助吗?
得分 0
添加一条评论
there is a website where you can get all the parts to this phone i actual just cracked my screen.. where sprint wouldnt replace it . Sorry #$$#@$& tried to get me to buy a new phone. But the screen was only 100 bucks on this website.. http://www.repairsuniverse.com/info.html
这个答案有帮助吗?
得分 0
添加一条评论
Check ebay the gadgetfix store has it for $62 bucks.
这个答案有帮助吗?
得分 0
添加一条评论
I found the Evo 4g installation adhesive sold seperately at
http://www.durapowerglobal.com/HTC-Evo-4...
and the replacement glass screen digitizer for $35
这个答案有帮助吗?
得分 0
添加一条评论
Hey I have a Htc Evo 4g phone everything works but theres a problem with th screen sometime when I go to dial a number or some numbers to call it fails a the numbers in it start calling automatic.... Sometimes I what to text some patters in it do da same I touch letter j in it goes to k in some won't even tap... I want to know what's wrong in do I need to replace my screen?? Plz help ASAP
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
jesus christ what a $$$^!%* mess this thread is. Great work with your SEO! Too bad the answer to my problem is nowhere near here!
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
You can get adhesive from durapower global, check it out:
http://durapowerglobal.com/HTC-EVO-4G-Di...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
chris smith 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 28
总计 18,862
