跳转到主内容
Power on pads for Mid 2012 MacBook Air 11" A1465
I found information for a 2010, 2011, and 2013 macbook air but I can't for the life of me locate the power pads for the mid 2012 macbook air 11". Here are photos and I hope a kind soul would be able to assist me.
I've only tried the flat head screwdriver method at this point but realized it wasn't a solder point. Yes, I'm an idiot =P
Here's a photo of the board and I just marked locations where I think it might be located based on what I've read.
I figure if powers on then I will replace the keyboard but if it doesnt then it would also involve the logicboard in which case I wouldn't bother fixing it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
已选择的解决方案
Asahi, here you go. Do not bridge any of the other contacts you marked.
这个答案有帮助吗?
得分 5
5条评论:
OMG!!! This worked!! Thanks oldturkey03 =) I'm sure this will be useful for all the other 2012 MBA 11"with the same issues. Thank you thank you thank you!
完成的
you are welcome;-)
完成的
thx for photo, start my air after died power key button
完成的
You are FANTASTIC! do you know where the serial number for this board might be?
完成的
Diego V not sure what you mean by serial number
完成的
添加一条评论
See this Answer - your case is similar. Use care shorting random pads on the logic board, you can kill it.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
asahi21 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 41
总计 10,006
