跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Capacitor replacing on iPhone 5
Hello.
I've replaced the "Audio Control and Power Button Cable", thank you very much for the step-by-step.
As I almost finished, my screwdriver slipped and I've removed a couple of capacitors (I think that's what they are).
Here is a picture, it's right next to the battery connector:
Can someone help me to identify so I can (hopefully) re-solder them?
Thank you.
Peter.
Update
Hello oldturkey03.
I'm just trying to see if these are the parts needed:
The manufacture codes are C0402C0G1C560J020BC for C279 and MMZ0402S121C for the FL11.
Thank you.
Peter.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Peter, that is reference designator FL11 is a 120ohm 210mA inductor in a 01005 package and
reference designator C279 is a 56PF 16V 5% capacitor in a 01005 package. Hope this helps, good luck.
这个答案有帮助吗?
得分 5
6条评论:
Hi oldturkey03. Thank you for the info. I'm trying to get the parts. £0.18 for a part and £12 delivery :(
完成的
Hello oldturkey03.
Thank you.
Peter.
完成的
Hi guys! where you buy this parts? please help me crushedrepepper@gmail.com
完成的
CRUSHED RED PEPPER, they are available at digikey.com
完成的
What does this look like on the iPhone 6?
完成的
显示更多的1条评论
添加一条评论
FL 11 is required and will have to get back in place for the phone to work. Honk if you need microsoldering assistance.
jessa
这个答案有帮助吗?
得分 4
3条评论:
Hi jessabethany. Thank you for the comment and support :)
I will probably need some assistance as soon as I get the parts.
完成的
Hi Jessa,
can you confirm me, that there are "unnecessary" parts in this section?
I ask because I ripped off 2 parts there, but the phone is working. Cant see any bug so far.
Maybe I ripped of 2 capacitors, that was used to smooth voltage-fluctuations, as I remember they are often near to power-supplys.
greetz revnu
EDIT: even if my assumption is right, what type of long term-effect I can expect bye missing smoothing-caps?
完成的
Have the FL11 and C270 pry damage on a 5C. What you will encounter is
- Battery gas gauge is incorrect
- Cellular call radio lose like 5-10dB signal strength
完成的
添加一条评论
wow! you guys rock….
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Peter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 15,306
