跳转到主内容
网络设备包括路由器,调制解调器,和共享存储器的维修信息。
I need your guidance for earthing to prevent from lightning
I need proper earthing guides to prevent from damages due to lightning and thunder,i also need what type of cables to be laid with any extra sheath wherein lightning will not penetrate,kindly guide me thank you,This is for modems and programmable logical controllers which will kept in an enclosed chamber in an open field to monitor the data and ingestion of manure through drip irrigation in TEA FIELDS in a hilly region
NARAYANAN LAKSHMANAN INDIA
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
NARAYANAN LAKSHMANAN, I'd use a grounding rod and drive that into the ground, then connect all ground wires to that. For lightning protection, a ligthning rod seems to be the only answer. Check the white paper on here and some great information about Cat 5 outdoor equipment on here. You will of course consider what equipment you use. If it does have a n outdoor enclosure, it is most likely designed to be electrically insulated. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
1条评论:
Thank you so much for the good answer,I am obliged.NARAYANAN LAKSHMANAN
完成的
添加一条评论
添加你的答案
NARAYANAN LAKSHMANAN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 109
