跳转到主内容
加入维修社区 - 创建账户
Panasonic SC-PM31 是一款包含卡带播放器、5 碟 CD 播放器和收音机的 CD 立体声系统。于 2005 年 3 月发布,型号为 SC-PM31。 它配有一个立体声主机和两个扬声器。此维修页面重点介绍主机。
Why won't the system read CDs?
When I insert a CD, it will not play. The display says "reading", but no sound comes out. The CD plays fine on my computer, but doesn't work on this system. I have tried this with multiple CDs, and the same thing happens to all of them.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
8条评论:
I have a very similar problem with a Panasonic SA PMX 70B. At times it plays but stops after ~1 minute and as with Michael Ebert's problem the same happens with multiple CDs. On removal and re-insertion of the CD the display says "reading" for a few minutes and finally "no play".
Could the problem be something to do with CD alignment or possibly something needs cleaning?
Any comments appreciated.
由完成的
Hi @Niall ,
The CD player could simply be defective. What kind of internal connector does it have?
You could try cleaning the head with one of the Laser Lens Cleaner Cleaning Kits with the tiny soft brushes.
Otherwise the laser could be slightly out of alignment.
由完成的
Mike,
Thank you for your response.
I will try one of the laser lens cleaning kits as you suggest and post some photos of the CD drive and its connectors after I open the box.
Best regards
由完成的
@Niall
You posted your photo as an "Answer" which it is not.
So it looks like it is all proprietary so no simple replacement of drive. Just get one of the cleaning disks. I wouldn't open it up further. No Point.
由完成的
Mike,
Ok and thanks. I will post another comment when I have tried the cleaning disk.
由完成的
显示更多的3条评论
添加一条评论
2个答案
The system may be muted, or the speakers may be malfunctioning. Check the troubleshooting guide under the "CDs will not read" section for possible solutions.
这个答案有帮助吗?
得分 0
添加一条评论
The photo below shows the CD player after it was removed from the hi-fi enclosure. It seems that there are just two ribbon cables connected to the CD player.
Sliding the white plastic moulding, in the centre of the picture, causes the CD tray to eject but this does not really permit further access to allow the head to be cleaned.
It seems to me that the larger circuit board in the picture will need to be removed but I am concerned that this removal may give rise to some alignment issues when it is put back.
这个答案有帮助吗?
得分 0
4条评论:
It’s the loading switch it has (Oxidised) not giving zero ohms closed 👍🇯🇲
由完成的
Search cd Mechanism for micro switch, clean with fine Emery. That should solve the issue (common problem)
由完成的
Hi @raymondcam98880
I prefer to clean with isopropyl alcohol, a good cleaning solvent, as close to 99% pure as possible. Even very fine emery paper scratches the contacts.
由完成的
True but I like to resurface the contacts don’t have the problem recurring. The main point is is I am pointing out the problem.what do you think?
由完成的
添加一条评论
添加你的答案
Michael Ebert 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 33
总计 7,245
