跳转到主内容
加入维修社区 - 创建账户
Western Digital My Passport 硬盘。USB 3.0 便携式外置硬盘。
How do I get data off?
The drive shows up on my computer, I can access it, but when I try to pull it off it goes EXTREMELY slow and I get an error. I need help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
2条评论
We need some context. What computer are you using? What operating system? Are you connecting the drive to the computer through USB, or FireWire? If it's USB, is it USB 1, 2 or 3? What (if any) error messages are you seeing?
由完成的 分享
I have the same issue. we have hung this drive off Quad core computers running Windows 7 and Windows 10, swapped cables, booted systems with it attached ... same problem. Suspect bad controller.
由完成的 分享
添加一条评论
5个答案
最有帮助的答案
Try running a disk or file repair application on the drive. Also try using a different system and cable, to make sure its not your computers port and the cable its self is good.
这个答案有帮助吗?
得分 2
添加一条评论
Use chkdsk /f to your external drive. Example i is your drive then the command
chkdsk/f i:
Wait until finished
这个答案有帮助吗?
得分 1
添加一条评论
I managed to get data off by using TestDisk on Ubuntu because it was actually recognizing the drive, but let me tell you, because the WD My Passport HD had some problems, it took a LONG time. I ended up just getting off the files that were irreplaceable like pictures and stuff.
这个答案有帮助吗?
得分 1
添加一条评论
What is a reputable company inside the United States that can retrieve the data off of it?
这个答案有帮助吗?
得分 0
1条评论:
Assuming the disk has actually failed - that is, it isn't restorable with normal system utilities such as Disk Utility, Check Disk, Disk Warrior, DriveGenius, TechTool Pro etc. - Drive Savers in California is the one with the longest track record. It's expensive, so I wouldn't go that way if the disk isn't showing signs of physical failure, like clicking sounds or failure to spin up. I'm a Drive Savers reseller; click on my user name, and it will show my reseller code, which will get you a discount and a longer warranty.
由完成的 分享
添加一条评论
I believe that its mostly a hard ware issue. is copying your data from the drive to your PC the ONLY function that doesn't work?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
AZ Redneck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 26
总计 9,466
