跳转到主内容
Model A1137 / 1, 2, or 4 GB capacity / black or white plastic front
68 个问题 查看全部
A white screen in iPod, only works when charger is plugged in
My iPod only works when I plug in the charger, it won't work at all while i stop recharging. I've already change the battery, but when I turn it on again with the charger it only appear a plain white screen. Still, doesn't work while i put off the charger...can you help me please...?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I noticed you never got an answer to this. Are you still having this problem?
完成的
添加一条评论
1个答案
已选择的解决方案
Did you try resetting it? Press the center and top click wheel button for 6 seconds till the apple logo shows up. Did you try to toggle it? That means switch the hold button back and forth 5-10 times, then press the menu and center button until the screen switches off.
then plug it into its charger and it should work. And last but not least did you make sure that all the connectors are seated right and that all clips etc.are tight. Especially in this area`iPod Nano 1st Generation Display Replacement Good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Abram 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 13
总计 3,803
