F60 error on Panasonic DVD recorder
I have a Panasonic DMR-ES40V VCR/DVD Recorder that suddenly will not start up. After the 000000's finish cycling when I plug it in, it gives a F60 error code and won't do anything else. No power light, no fan noise, etc. I have tried the reset options in the user manual, to no avail. Googling the issue seems to point to a video issue, but no one can tell me specifically what. If anyone can help me isolate the problem, I will appreciate it. Thanks.
6条评论
Not only do I get an F60 error I have the VHS tape only half way lowered.
由 Hugh Kelly 完成的
Here's another repair experience, from EE Times magazine
https://www.eetimes.com/another-capacito...
由 When Ze 完成的
I tried unplugging and holding power button, as suggested by old turkey. First time it did not work. I ejected VHS tape and tried again and it worked! Thank you Thank you Thank you!!!
由 Linda Morreale 完成的
My Panasonic DMR-ES40V wouldn’t get past F60, so I replaced four bad capacitors on the power supply board. That got me to 12:00A and HELLO, but no further. I am able to use the remote to turn TV off/on and select AV2, but get “no signal” on the TV, and nothing more on the unit’s display. Is it toast, or is there something else to try.
由 Dave Callahan 完成的
Was there any fix to your issue? I’m getting to the same spots: HELLO and 12:00A
由 Todd Bradley 完成的
显示更多的1条评论
