跳转到主内容
加入维修社区 - 创建账户
于 2013 年 5 月发布。显示屏 - 1200 x 1920 像素,10.1 英寸。芯片组 - Qualcomm Snapdragon APQ8064, CPU - 四核 1.5 GHz Krait,GPU - Adreno 320。存储 - 16/32 GB,2 GB 运行内存。运行 Android 操作系统,v4.1.2 (Jelly Bean),可升级至 v4.4.2 (KitKat)。
screen broken but working
my tablet z touch screen broken, i want any professional guide to change a new screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
5个答案
最有帮助的答案
check here https://www.youtube.com/watch?v=2DQpbjzK...
这个答案有帮助吗?
得分 1
1条评论:
@kozzmic: That video only explains how to replace the full screen (LCD + glass + touch), not just the glass + touch. Seems you can buy the glass + touch digitizer without the LCD, and that makes the repair a lot cheaper, but maybe a bit more complicated: http://www.parts4repair.com/touch-screen...
Here's some insight on how to separate the glass + digitizer from the LCD. Looks like it's easy to do something wrong: https://www.youtube.com/watch?v=levTY6Ix...
由完成的 分享
添加一条评论
:) check this surprise ,
change or replace the front glass only https://youtu.be/-nFy-Ojt8oc
这个答案有帮助吗?
得分 1
添加一条评论
i have a broken screen and wish to change it and bye a new one
这个答案有帮助吗?
得分 0
添加一条评论
Here's the teardown in full
https://youtu.be/MdwBZ7JBxJ0
My daughter just broke mine... Not amused atm
这个答案有帮助吗?
得分 0
添加一条评论
HI!
It's a pain in the ass to do this and i think this dont justify to have the job done.
I used two keychain rings attached in a piece of Nichrome wire because it's very hard to broke.
I heated a little all the tablet and put everytime direct heat in the part i'm with the wire and did the job with very very carefull.
after i thought the worst part is done, i've come with the loca glue removing. I think it's harder than the first part of removing digitizer from LCD. I used Isopropyl alchool and did it finally. but some alchool go to backlight and i can do nothing. The display is now blotched with alchool in some parts.
Conclusion: With very patience you can do this but i don't think it worth the effort.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
blacksigma 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 37
总计 8,931
