跳转到主内容
The Dell Latitude E6500 laptop PC was released in August 2008. The Latitude has a 15.4 inch screen with a 500 GB hard drive
20 个问题 查看全部
I need to disable the PW on my laptop...
On my old desktop, via the motherboard. There's a jumper pin to disable the PW. Is there one on a Dell E6500 Latitude, and do you have a schematic of the MB and a list of the surface mount jumper designations?
Hurry...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Kevin Wilson, no there is not one. /most modern laptops no longer store the password in battery-backed RAM. those were the once you could reset by pulling the battery or a jumper setting. More modern motherboards use standard SPI flash chips to store the BIOS data. You should contact Dell and once you prove you are the rightful owner, they will help you. There may be a few ways to get it reset with your Service tag number. Check on here. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for the assist.
完成的
Hello Bro's i need help
I bought few day Ago 3 dell latitude, 2 e6500 and 1 of e6400.
My problem is ...I already had media creation tool windows usb stick and I Installed e6400 , perfect, is working.
But the 2 of dell latitude e6500, if I start those same : need authentication password and ....like this, so password is important problem, but I o haven't Any bios password got from the guy, which sell this....
So one of them is under laptop service tag: 6JCJN4J
And the other one also service tag:CJ3T34J.
IF I wanna try to enter anything nothing what I click on the tastur is to see on screen why? And also my windows usb stick is not helping to boot this....
Please I thing my Turkish old turkey user brother can yüzde yüz help 🙏 😊
完成的
添加一条评论
添加你的答案
Kevin Wilson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 2,097
