跳转到主内容
加入维修社区 - 创建账户
Xbox One Kinect, Xbox One 随附的游戏外设。全球热销2300万台。
Kinect is not recognize by console
my xbox one kinect suddenly stopped working and the console can't recognized it.
I tried so many things to solve this problem.
1) I resat the console.
2) I unplugged the kinect then I turn the console off then on then I re-plunged it to console again.
3) I tried it with my friend's xbox-one, but also not working.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
8个答案
最有帮助的答案
When you bought a new one use that.
Anyway tear down the faulted kinect, check for continuity the thermal fuse in J11 connector. If it's blown replace it.
这个答案有帮助吗?
得分 2
9条评论:
did you find somewhere that supplies the correct thermal fuse?
完成的
No, I didn't. I used a Bimetal Thermostat.
完成的
Well where did you find the bimetal thermostat? And what are the specs?
完成的
What if I just bypassed it? Hmmmm
完成的
显示更多的4条评论
添加一条评论
It doesn't look like a regular fuse, and they differ also.
It should say j11 on or around the coupling, usually it is either a 2 pin cream coloured flat fuse (might be black now) and it is plugged into a 2 pin connector on the Kinect 2.0...at j11
Or sometimes it's simply a 2 pin Fuse/coupling soldered directly onto the board which can make it a little fiddly to find but usually the latter
I will try to show you my rough first fix before I changed the test bypass and neatened everything up, but hopefully you will get the jist.
You should find it here
This is how it looked on my K2.0 board
And this was the rough bypass test during my fault finding.
And it worked! It was my Eureka moment! Lol
I hope this helps.
All the best.
这个答案有帮助吗?
得分 1
2条评论:
I know this is over two years old, but wouldn't it work the same to solder the two leads where the fuse would be?
完成的
It's even more years old, but I just tied together these two yellow cords and it works for now, while I'm waiting for fuse to deliver.
完成的
添加一条评论
Try following this Xbox support guide if you have not already:
https://support.xbox.com/en-GB/xbox-one/...
However i am not 100% sure this will fix it. If it does not it sounds like you will have to send it off to Microsoft for repair.
这个答案有帮助吗?
得分 0
添加一条评论
You can bypass fuse temporarily just to rule out that it is indeed the fuse. I would advise not keeping it on when your not playing and to also turn the kinect off if you have been playing more than an hour just to alow the unit to cool down. I have ordered the bimetal fuses and am waiting now to test. I will give some feedback soon as well as a video on how to get to it.
这个答案有帮助吗?
得分 0
添加一条评论
I did bypass the fuse j11 and it has been perfect ever since, I bypassed it with some 6amp stranded copper wire to test its functionality.
Once proved that it worked for a few days, I then replaced it with some 1.5mm solid copper core insulated cable to make sure that would never be a weak link again.
It has been perfect, and I use the Kinect daily now, and also heavy duty usage for my own stream twitch casting.
I am an ex-military technical engineer and domestic electrician, I am fully aware of any risks.
It will be fine, besides any faults and your power brick will let you know and at worst your Kinect will just stop working given the minimal current that passes through the j11 fuse (which is tiny)
I can only assume that the j11 fuses that they originally used in the kinects were faulty,
so I would either suggest try to replace with a fuse of the same spec or (at your own risk of breaking your Kinect) just use my method.
I will probably replace it when I get round to it with a correct fuse but until then after 3 months of heavy use and never being shut down, I have total faith in the fix.
Is I said, it is perfect now. :)
这个答案有帮助吗?
得分 0
添加一条评论
Unfortunatelly my second kinect has stopped working on Xbox one fat. When I connect kinect to the Xbox, it tell me for restart, but it won't came up. I thought there is a time for repair the blowed fuse.
Today I had some time and tear down that, because of j11 fuse problem. But there isn't a fuse.
Anybody can help me where can I found the faulty part on the newer mainboard?
这个答案有帮助吗?
得分 0
添加一条评论
That's main kinect mainboard.
No fuse at j11 nor connector for fuse.
I will make some measure tomorrow.
Thanks
这个答案有帮助吗?
得分 0
1条评论:
did you find a solution
完成的
添加一条评论
Hi, i have a mainboard with no fuse connector too
这个答案有帮助吗?
得分 0
1条评论:
did you find a resolution
完成的
添加一条评论
添加你的答案
Ismaeel 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 40
总计 5,632
