跳转到主内容
First generation of the Kawasaki Ninja 500.
3 个问题 查看全部
How to clean the carbs
Hi I'm new to motorcycles. I just got a 1993 Kawasaki ex 500. The guy I got the bike from said he knows the carbs need to be cleaned. Can someone please tell me how to do this. ? This is my first bike so I have no clue what to do. And a repair shop wants 400 and up. And I don't have that. To spend right now. Any help would be great thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Chris Hilliard, take a look on here. different bike, same idea. You can find step-by-step instructions on here. I'd suggest you get a carb overhaul kit and get to it. take your time, it is not as easy as it seems. The numbers for your Kawasaki carbs are 15002-1492 LH 15002-1493 RH. Armed with that you should find a rebuild kit relatively easy. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
1条评论:
Hey, thank you so much. I wrote this down. And I'll check the site. Thanks so much. I can't wait to have her up and running.
完成的
添加一条评论
https://ninja250.org/ = THE Bible for the 250cc-300cc Kawasaki’s. Good advice for all motorcycles also.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris Hilliard 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 2,033
