跳转到主内容
加入维修社区 - 创建账户
Zenbook Prime UX31A 的 Windows 8 触屏兼容版本
sd card slot problem
My Asus Zenbook Touch UX31A SD Card slot has stopped working. I tried updating the driver but that didn't work. I found if I stick the card in and out sometimes it works briefly.
Do I need to replace it? If so it is something I can do? I have a lot of experience with fixing desktops but not lap tops.
Where would I get the part?
thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
最有帮助的答案
Hello,
I just had the same problem with my Zenbook UX303LB.
Solved it as follows (I just translated this, hope you find what I mean):
  1. Start Devicemanager (Windows Key + R, devmgmt.msc, run)
  2. Searched for the Device with the 'problem sign'
  3. Right Click and Update Driver
  4. Search manually
  5. Choose from a list of drivers
  6. Select USB MassStorage Device
  7. Next
Solved it for my system, hope it will help you as well! :)
Cheers!
这个答案有帮助吗?
得分 4
3条评论:
Could you please share the link of the lastest driver of card reader for this model? Thanks
由完成的
I don't understand what i should after pressing windows sign +R. Can you help me ?
由完成的
Hi @dangelo_r12,
Type devmgmt.msc in the box that appears after you press Win +R and then press OK.
Device Manager will open, follow the procedure above.
由完成的
添加一条评论
Open the laptop as per instructions from the UX31A keyboard guide. Make sure the ribbon cable that spans the CPU fan is properly seated on both ends. If this does not work, the replacement board is separate from the motherboard and is usually called the "IO board" or "media board".
这个答案有帮助吗?
得分 0
添加一条评论
I have two Asus laptops that did the same thing I lost the SD card device all I did was to remove the SD card and replace it with a different card, it worked. Then I removed the card and replaced it with the original card and it worked.
Very odd.
这个答案有帮助吗?
得分 0
添加一条评论
Put in a different card, then right-click the card and click eject before removing it. You'll be able to put the same card in again and it'll work fine.
这个答案有帮助吗?
得分 0
添加一条评论
Could try in device manager to select the card under drives, then right click for properties, and under policies select “better performance”
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
james 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 25
总计 8,289
