跳转到主内容
加入维修社区 - 创建账户
Whirlpool(惠而浦)品牌顶开式和前开式洗衣机的维修指南与支持。
How can I address the F1 error code?
My Cabrio washing machine constantly stops during the wash cycle and shows an F1 error code. I hit pause and start at least 50 times over two hours to complete my wash. Is there a part I can replace so that my wash cycle operates properly?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 12
4条评论
An Luther then the f1 error code at the same time e9 appears an door will not open
由完成的 分享
i have a washer the front loader and when i press start it dosnt even do anything just f1
由完成的 分享
What if it just shows an f flashing?
由完成的 分享
Cabrio washer..error code F1 and E5. Unplugged for 15 min…then it blinked 888. Don’t know wha to do?
由完成的 分享
添加一条评论
4个答案
最有帮助的答案
Usually, it's a problem with the control board. By replacing the control board, you should be able to fix the problem. However, it might also be a problem with the hose, something might be stuck in the hose. There is even a web site dedicated to the F1 error :) Whirlpool F1 Error web site. There you can find detailed instructions on how to check and clean the hose or if needed, replace the control board and also where to buy a proper one.
这个答案有帮助吗?
得分 3
添加一条评论
I had the same issue. I replaced the board and the F1 error was still there. I decided to put a hose clamp on the hose coming from the board. Boom my F1 error is gone. Hope this helps.
这个答案有帮助吗?
得分 1
2条评论:
I hope this is will work. Which hose is it?
由完成的 分享
It worked for me, my wife and I are very thankful for your post. I connected the hose, ran the diagnostic mode, fixed. We’re washing clothes!
由完成的 分享
添加一条评论
Common, Water Pump. ( Clogged or Broken )
to get door to open, use wet-dry vacume to pull water out from washer, by vacumming water out from drain hose. ( the tube that goes to the hole in your wall. =-D)
Soap dispenser Missing Magnet sensor, or soap dispenser is not all the way in.
Motor control Unit is bad, or door lock solenoid is damaged.
这个答案有帮助吗?
得分 0
2条评论:
Drain pump. (take wet dry vac-vacume water out of washer through drain hose)
try machine again.) works( replace pump)
soap dispenser bad or half out.
bad motor control or door lock solenoid is bad replace door lock.
由完成的 分享
I have a Cabrio Washer, Replaced the Control Board and the washer wont do anything. I am at a loss.
由完成的 分享
添加一条评论
A friend of mine had the same issue F1 code. We tried to unplug for 10 minutes and plugged it in about 6 or 7 times. We checked the breaker box a couple times, didn't realize one side of the double breaker was f##@ed. Changed out the breaker. No problems.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bob 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 35
过去 30 天: 144
总计 96,022
