跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Strange circle on display
Strange circle on display and if screen won't start when it's charged it's beeping every 5 seconds or so.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Horalipa, looks like a bad LCD. Replacing the LCD should fix this. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
2条评论:
Hmz, but can it go like that without even doing anything to the phone? I've put it on table and turned it off, never back up again with clear image and if sometimes the screen won't start it just beeping every 5-6 seconds like this: https://www.dropbox.com/s/lhai7zcdx74ckz...
完成的
Yes, it is possible. Not everything gives warning before it fails. Sometimes things fail without any prior indication.
完成的
添加一条评论
添加你的答案
Horalipa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 206
