跳转到主内容
加入维修社区 - 创建账户
iPhone 的首款型号,型号 A1203,提供 4、8 或 16 GB 容量,采用铝合金背壳。维修时需要进行大量的撬开操作,可能还需要用到焊接。此页面旨在帮助用户对 iPhone 2G 进行故障排除、维修及寻求帮助。
How can I unlock it without my computer?
I just found my iphone 1st generation but i forgot my password,how can i unlock it without my computer?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
As far as I know, you will have to install iTunes on your computer and restore the firmware of the device with iTunes. It should be noted that you will lose all data on the iPhone if you use this procedure.
1. Plug your iPhone into computer with iTunes installed, and open.
2. Shut down the iPhone (hold power button and slide to power off)
3. With the iPhone off, hold the power button for three seconds
4. While holding the power button, press and hold the home button at the same time.
5. Hold both buttons for 10 seconds.
6. Let go of the power button, but continue holding the home button.
After roughly 8-10 seconds, you should see a prompt in iTunes telling you that the connected device is in recovery mode and needs to be restored. From there, follow the prompts to download the iOS firmware for your device and restore it to factory defaults.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ray toomata 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 670
