跳转到主内容
激光传感器 4按键 轨迹球
15 个问题 查看全部
Purchase and replace ball
Something small and hard fell in the mouse track ball area and while i was pressing it (upside down) on a piece of paper to clean it, that little hard piece of dust, carved the surface of my track ball making it unable to scroll without jumping around!
So im now in the need of purchasing a new ball and replacing it! Does the ball as a part exist? Because i can't find anything on ebay! Any help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Does anyone know how to find the provider of the scroll ball Apple uses to equip the Mighty mouse?
完成的
添加一条评论
2个答案
已选择的解决方案
Sadly, the Mighty Mouse and the Magic Mouse are deemed as not repairable by Apple. You're only hope here is to see if you can locate a dead one to steal the part to make yours whole again or look into getting a new one.
这个答案有帮助吗?
得分 3
2条评论:
Where can i look for a dead one?
完成的
eBay is a good start, local tech flea markets
完成的
添加一条评论
genik, I am sure that you have already checked these instructions. Post an image of your trackball as well as the damage with your question and lets see if we can assist you finding what you need. If you can measure the diameter of the ball and let us know what you find. the scroll ball is nothing but a "rubber" ball with a metal core. I would suggest to measure the existing ball and get something the same (or at least very close to it) ball from places like this. Hope this helps, good luck.
update
any mechanic or machinist should be able to help you. All you need is a set of vernier calipers to measure it.
Update (01/06/2016)
I thought by now you had found what you needed. Anyhow, the diameter is 7.15mm/0.2815inch
这个答案有帮助吗?
得分 3
6条评论:
Hmm interesting, only i don't know how to measure exactly the diameter!
完成的
Is this tool offered in the Pro Tech Toolkit? Cause i see something similar... i think!
完成的
Has anyone managed to measure the diameter of the scroll ball?
完成的
genik, I sure would have thought you had it accomplished by now. I do have one left, so let me know if you want it:-)
完成的
You have what left? A scroll ball?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
genik 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 10
总计 544
