跳转到主内容
加入维修社区 - 创建账户
苹果公司于 2012 年推出的第一代 7.9 英寸 iPad mini,拥有 16、32 或 64 GB 存储容量,搭载 A5 处理器。
How to fix screen glitch?
Whenever I am using my iPad Mini it occasionally switches apps, types on its own and opening apps on its own, and also when I am watching videos it pauses and unpauses by itself. I tried everything to get rid of this please help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 122
41条评论
I have this problem too I have the same thing and it types on its own and taps moves it's annoying
由完成的 分享
My iPad shuts down while your in the middle of something and it takes random screenshots and it turns its self on when I shut it down HELP‼️
由完成的 分享
my iPad doest stop glithing like crazy it closes it opens random apps it almost wanted to fro it out of the 4rt floor
由完成的 分享
When I try to turn my iPad mini on and I do my password it just keeps on glitching me out and also my screen is really cracked please help me fix it
由完成的 分享
I have the iPad air, for some undefined reason it started the glitching stuff, tried to backup and hard reset, nah!!! Doesn't mean anything, so I was thinking about buying a new screen, but I think that I fixed it by chance. How? Easy, I went to setting-general-Accessibility, then I activate the (REDUCE MOTION)=ON. Worth trying. If possible, let me know your result, then share it with everyone.
由完成的 分享
显示更多的36条评论
添加一条评论
6个答案
已选择的解决方案
Did this happen after a creen replacement?
If so this happens when the black tape for orignal screen isnt transferred to new screen see pic there's gold contacts need covered with the tape
这个答案有帮助吗?
得分 20
9条评论:
how do u do that though, because I got my screen replaced and all of this stuff happened am I able to take it to a store and get it fixed?
由完成的 分享
Ahh when I watch on my iPad it glitch and it went to another video or app plz help me I will give you 50 dollars
由完成的 分享
My ipad mini was a giltch still
由完成的 分享
meh ipad keeps going crazy idk wats wrong with it
由完成的 分享
it just now when I play a game on it
由完成的 分享
显示更多的4条评论
添加一条评论
If the taping doesn't solve, then this could be a crease in the digitizer flex as next candidate. A new digitizer will solve--remember to keep the flex bent toward the LCD as in the original.
这个答案有帮助吗?
得分 12
3条评论:
Thank you very useful.
由完成的 分享
I don’t get it
由完成的 分享
Everytime I play a game on my iPad, when I loose, it glitches in middle of ads and then it automatically goes back to home screen. However, it might just be the game, paper.io, that causes the glitches, because since I downloaded that game, that was when the glitches started. But i really dont want to delete paper.io, since it's my favourite game, so is there any way to stop the glitches without me deleting the app?
由完成的 分享
添加一条评论
My iPad is constently doing the same and i couldn't get it to do anything or stop at first, but I find that getting it to shut down and reload/restart works best. Sometimes it works by just pressing and holding the lock button, then 'slide to power off' (this doesn't always work, so I also sometimes have to press the home button and the lock butten at the same time and hold them both down until it reloads/restarts
(I'm not sure if it will actually work on yours, but it's worth a try as it works on mine).
这个答案有帮助吗?
得分 7
5条评论:
i dont know if im doing this right
由完成的 分享
My off bitten doesn't work so how would I do it?
由完成的 分享
what type of ipad do you have because it could depend on the type of ipad you have
由完成的 分享
how do i stop my ipad from gilitching
由完成的 分享
is a new ipad air
由完成的 分享
添加一条评论
Shut it off turn it back on
这个答案有帮助吗?
得分 4
2条评论:
It doesn't work.........
由完成的 分享
It only seemed make it worse
由完成的 分享
添加一条评论
Plug your device into your computer with a USB cable. Hold the Home and Power buttons for 10 seconds. Release the Power button but keep holding the Home button. After about 15 seconds you will be alerted by iTunes saying that it has detected a device in Recovery Mode.
这个答案有帮助吗?
得分 4
添加一条评论
The answers about the creased digitizer flex and taping the gold contact areas are all definite fixes for this. Let me add one more that I didn't notice until I swapped a digitizer 3 times on an iPad mini. The digitizer cable end has a piece soldered on where you plug it into the motherboard. The bottom of that piece that is soldered on usually has black or clear yellow Kapton tape. Sometimes when removing the broken one, the black adhesive on the case itself comes up. If your digitizer does not have black or clear yellow Kapton tape, then the solder points on the bottom of the cable will make contact with the iPad housing and cause this issue. I was at the end of my rope with this iPad before I figured this out. If this isn't the case for you, I hope it helps someone else.
这个答案有帮助吗?
得分 4
7条评论:
How did you fix it?
由完成的 分享
"If your digitizer does not have black or clear yellow Kapton tape, then the solder points on the bottom of the cable will make contact with the iPad housing and cause this issue."
Put electrical tape or kapton tape on the back of the digitizer flex cable.
由完成的 分享
Thank you
由完成的 分享
how did you fix it
由完成的 分享
As I explained above, if the replacement digitizer doesn't have any type of tape protecting the solder points on the connector from the digitizer, it will ground out. So add tape, preferably Kapton tape.
由完成的 分享
显示更多的2条评论
添加一条评论
添加你的答案
Stephen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 21
过去 30 天: 66
总计 131,552
