跳转到主内容
The Samsung Wave II S8530 (or "Samsung Wave II") is the Successor of Samsung Wave S8500 smartphone running the bada 1.2 operating system designed by Samsung, which was commercially released on October, 2010.
Charging problem due to problem in charging pin of Mobile
I want to change the charging pin as it has damaged ,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Sunil, it sounds like you are looking for part number 3722-002919, which is the micro USB port for your phone. You can get it from places like this as well as many others. It is soldered to the logic board, so it will require some great skills and good tools. you will have to disassemble your phone and remove the logic board to get to the port. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
Hey sunil,
You can buy all of the accessories you need for this certain phone here
-Hope this helped
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
sunil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 902
