跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 个问题 查看全部
Fan goes to maxspeed at startup, computer is laggy
The fan goes to maxspeed sometimes even at startup, so I doubt that its because of heat.
Apart from it being annoyingly noisy it also lags quite significantly.
I chose the setup with the strongest CPU etc and I used to play games at max setings without any problems. I have bootcamp installed, but I have the same lag/fan problems in both modes(win7/OSX), so that cant be the source of the problem.
Any ideas?
Is there a way to test it for hardware-malfunction?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论
Please give us the last four figures of your serial number. Also, has the hard drive been changed?
完成的
2.8 GHz Core i7 (I7-2600S)
Intro Date: May 3, 2011 Disc Date: October 23, 2012
Order No: BTO/CTO Model No: A1311 (EMC 2428)
Subfamily: Mid-2011 Model ID: iMac12,1
Std RAM: 4 GB Std VRAM: 512 MB
Std Storage: 1 TB (7200 RPM) Std Optical: 8X DL "SuperDrive"
Complete iMac "Core i7" 2.8 21.5-Inch (Mid-2011) Specs
完成的
The drive has never been changed.
完成的
添加一条评论
1个答案
已选择的解决方案
First lets see what the builtin sensors are telling us. Download this app: Temperature Gauge Pro so you can see whats going on. snap a screenshot and post it here for us to see.
You should create a bootable thumb drive (OS-X) so you can check your HD using Disk Utility. Give that a try to see what it tells you.
Often I end up cleaning the dust buildup internally and if needed (on older systems) reapply a fresh coat of thermal paste on the CPU & GPU's. But before you go down that path see what the tools tell us.
这个答案有帮助吗?
得分 3
16条评论:
Hi and thank you for your reply.
The same day you wrote I had claped my iPad gentle on the back-side. I guess I got the idea that it could be a dust problem, so that if I padded it a bit all over the dust might rearrange itself.
That strategy seems to work temporarily. (it also kinda points in the direction of dust-buildup). It just gave me a week without the fan speeding up and all that - which also were the reason I did not respond before now. I needed the problem to be present in order to test it.
And now its back.
The app tells me that temperatures seem fine (in the range between 35-46 degrees).
The ODD fan is at its lowest 1400 RPM
The HDD fan aswell at 1100 RPM
But CPU fan is at max speed 4000 RPM
Do you need more info?
Thanks alot!!
完成的
Did you create a bootable thumb drive so you can check your HD? I would start there. While it may appear to be a CPU kind of problem a HD that is in trouble will also cause the CPU to get hotter.
完成的
Hi Dan.
I made a bootable SD-card-thumbdrive with Maverick. Toke some time to google what it was and how to create it, but now im ready.
How do we proceed from here?
完成的
Good, now go into you system preferences with the USB drive connected and set it as the startup disk. Once your system boots up (it will take longer so don't panic). Go into the USB drives application > utility's folder to locate disk utility run it checking your internal HD. How is the system running? Also did disk utility find any errors on the disk?
完成的
Hi Dan. The HD checked out fine. I checked the whole disk and that went fast. Then I checked Mac Partition - it toke longer and checked out fine. For my Bootcamp partition, I couldn't press the check-button. But I assume that is ok too, since the whole disk checked out fine. I know.. what logic! :-)
So whats next?
Some guy in here asks for the last 4 digits of the serial#. What can he make of those?
完成的
显示更多的11条评论
添加一条评论
添加你的答案
Albert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 736
