跳转到主内容
加入维修社区 - 创建账户
爆米花机及爆米花制作器的维修指南。
Popcorn machine not turning on.
Are there any fuses that would keep the machine from getting power? Where would it be located on "the classic 16 pop" machine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
If you're talking about the Paragon Classic Pop, I don't see any evidence of it having a fuse (in the spare parts list). If the machine has no power at all (ie. heat lamp doesn't turn on, kettle doesn't warm up, motor doesn't turn) I would first check the outlet to make sure it's working then work your way into the machine with a voltmeter, checking each connection to see where the current flow stops. It could be as simple as a bad power switch.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Claudius 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 7,139
