跳转到主内容
The Canon Powershot A1000 IS features a lens with 4X optical zoom and a focal length of 6.2mm to 24.8mm and maximum f-stops of f/2.7 and f/5.6.
How to clean the CCD and the Lens Zoom Unit parts
As you may know, all compact Cameras that have a collapsed zoom lenses parts link this camera is very sensitive to dusts and sands. and after a day on the beach you may have this kinds of cameras defective. because some sand particles may go in between the lens parts and make it jammed.
And because the sand is very tiny it may go through the shutter and may jam it too and make the pictures brighter and blurred because it cant shut correctly in time. also some of the sand particles may settle on the CCD and cause some blind spots can be seen on all produced photos, located in the same place.
before buying a new part of the lenses set, I need to clean it up first, cleaning the camera lenses parts and the CCD.
Thank you in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
hsawires, here is the teardown that will help you get to the parts you are trying to clean. For the lens assembly itself, check the attached images. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
3条评论:
Thank you so must for your reply.
the materials you post it, I think it is very useful but if you could deliver a bigger readable version of this two page I will be so grateful.
完成的
when you hover your mouse cursor over the image, click on "view original. this will open the images up to a very readable size:-) Otherwise you can contact me by email. My address is in my profile. That way I can send you those images;-)
完成的
Thank you so much.
is it possible to clean the CCD as well as the shutter ... I figured out that the lest part are now accessible for cleaning ans I think it is easy to do that. thanks to you.
please check you inbox.
完成的
添加一条评论
添加你的答案
hsawires 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 429
