跳转到主内容
Display problem with MacBook Pro 15" A1211, fix?
My MacBook Pro 15 inch model A 1211 is having a problem with the display. The display is bright in the center and dims within a couple inches from the edges. Do I need an entire display assembly, or can I just get away with a display inverter board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
To ensure this is not a GPU or VGC issue you could connect to an external monitor to ensure you do not observe the same thing.
If you saw the same shadow or dim edges that would indicate it is the chip, not the internal display chain. If the problem is the chip you'd need a new logic board or the current board "re-flowed" or possibly the GPU replaced (they are soldered to the logic board). This would not be a DIY project. There are services on e-bay that offer Graphics/logic board repair. (No I can't recommend anyone).
Replacing the inverter would be easier and cheaper than replacing the display, and replacing the entire display easier than trying to replace just the backlight.
这个答案有帮助吗?
得分 1
添加一条评论
mpias, that is usually caused by bad CCFL's (Backlight bulbs) in your LCD panel. To repair this you would have to replace the display panel. Use this guide for the repair. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mpias 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 505
