This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
Brad Klopfer @bradklopfer
声誉积分: 1
发帖于: 2014年8月17日
Must push gas pedal down to start. Will start and run untill I remove my foot from gas pedal.
这是一个好问题吗?
oldturkey03 @oldturkey03
声誉积分: 782.8千
1.1千
893
2.3千
Brad Klopfer, this could be caused by a bad idle air valve. You could try and removed the Idle Control Valve clean the carbon out of it and see if that makes a difference. If not, I would replace it and see what happens. Hope this helps, good luck.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 842
