跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Dead iPhone 5S after water damage
Hi out there!
I just bought a water damaged iPhone 5S from a friend. He had the phone in a zip lock bag on a canoe trip and unfortunately condensation got into the bag. From what i heard from him, he tried to dry it somewhere warm, but the phone was completely dead.
I have taken the phone apart, and cleaned off any corrosion on the logicboard using 99% Iso alcohol, but still there is no life. I have now removed all EMI shields, and found a little corrosion under these too, which I have also cleaned, but there is still no life :(
Anyone have some tips for what i can try to revive the phone?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Soren Jakobsen, once properly cleaned replace the battery and the dock connector. this is a must because of corrosion damage as well as the reaction of the old battery to water. The re-evaluate and see what happens. Water damage is the hardest to trouble shoot as well as the toughest to repair. Any one part on the board may have failed, so it will require patience and a good eye to check for damage. Hope this helps, good luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Soren Jakobsen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 1,348
