跳转到主内容
Repair and disassembly guides for guitar amplifiers.
71 个问题 查看全部
I have power but no sound
My Fender Champion 30 amplifier has power, but I get no sound through the speaker. I looked at the circuit board. welds looked good. My volume control knob is missing and the stud the knob goes to is broke off. I'm thinking this is the problem. I get no sound of static through the speaker. I can't find a related pic of the circuit bourd or were to go to get a replacement.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
anthony, it is entirely possible that the broken pot is your issue. It would be great if you could post a picture of your amp's logic board with your question. The volume potentiometer for the Champion 30 is a 50K 15A which appears to be a "log Pot" you should get those pretty much anywhere, try Mouser.com or Digikey. com, just watch the shipping:-) If you really want to, you can get original replacements from here Of course, you will need to know how to solder to replace it. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
2条评论:
I'll keep you up to date about the fix. thanks
完成的
I did change the potentiometer.Now it works.I have another issue. When I turn the amp off, I get a loud pop or loud click. I turn the volume off and I still get it. Any ideas?
完成的
添加一条评论
添加你的答案
anthony 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 2,842
