跳转到主内容
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
153 个问题 查看全部
What mileage does my car need to be to replace brakes?
When should you replace brakes?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Brake wear is dependent on how you drive. It's different for everyone. Have your brakes inspected at your local dealer not a brake shop. Brake shops are notorious about giving you a low estimate then "finding" a lot of other problems.
这个答案有帮助吗?
得分 1
2条评论:
City short trip driving "uses" more breaking than does long trip highway driving. Most cars have wear indicators that squeal or squeek indicating replacement need. So if your breaks are noisy they probably need replacement - unless they were noisy and are now quiet - because you wore through the wear indicators!
完成的
完成的
添加一条评论
Also when driving or braking (could be only for a moment when you brake) if you hear a slight or pronounced squeak you need to take your vehicle to have the brakes inspected. The time for routine brake replacement should be mentioned in your owners manual, but I agree with Mayer it is very highly affected by the way you drive and the environment you drive in. I found that driving in the north I replaced brakes for the same vehicle twice as often as in the south.
Take care having brakes inspected at a dealership. With the downturn in the automobile market some dealers tend to take advantage of those who look and/or act worried. (my mom found this out the hard way when a dealer tried to charge her $450 for a brake job and a replacement disc, thankfully she called me and I told her to call another dealer for their price on having the brakes replaced and a disc, the price was $320) She called the first dealer back and told them she would be in to pick up the car and go elsewhere. So if they give you a pricey estimate, find out exactly what they are doing and shop around between dealers (if that's an option for you in your area)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Deborah 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,440
