跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
710 个问题 查看全部
AMD HD 6770M upgrade is posible?
i'm triying to figure out if is possible to upgrade my current graphic card (AMD HD Radeon 6770M, 512 MB) replacing it by a better one. My iMac dates from mid 2011 with 27 inches screen. If is posible what card could be a good replacement?
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
已选择的解决方案
Try a search for this part:
27" iMac (Mid 2011) AMD Radeon HD 6970M 2GB Video Card
Item #: 661-5969 1009267
Replacement, 27" iMac (Mid 2011) AMD Radeon HD 6970M 2GB Video Card
http://www.welovemacs.com/6615969.html
See @danj answer here:
How to replace the video card?
这个答案有帮助吗?
得分 3
添加一条评论
Sorry, your system does not have a replaceable graphics card.
这个答案有帮助吗?
得分 1
8条评论:
Are you pretty sure? =(
完成的
The last one I opened up had a soldered MXM board.
完成的
Wait... they SOLDER the MXM card DIRECTLY TO THE BOARD?
完成的
I was surprised too! It was a system being returned from a field office in Asia. Instead of the pin header you'ed expect it was soldered pins!
完成的
The thing has a MODULAR MXM slot on the board there and populated, yet they SOLDERED the card to the board....
完成的
显示更多的3条评论
添加一条评论
Somebody has done it: https://forums.macrumors.com/threads/201...
这个答案有帮助吗?
得分 1
添加一条评论
would an external gpu work? There is nothing wrong with mine, other than I cannot play Blizzard games now :/ thanks to them upgrading their coding to Metal 2
这个答案有帮助吗?
得分 0
1条评论:
I don't think it would. High Sierra has introduced eGPU support as long as it connected through Thunderbolt 3 port. iMac mid 2011 doesn't even has a USB 3 port...
完成的
添加一条评论
The 27-inch (Mid-2011) does not have a soldered GPU board. It’s attached to the logic board but on the back side. To remove, you loosen the logic board, detach the GPU cooling heatsink from the bracket and remove two screws holding the GPU to the logic board bracket. It slides right out of the board socket.
I figured all that out and tried to replace my shaky board with what should be a working HD6770M and all I get is a black screen. Ugh. Old shaky board goes back in and I’m back where I started - pixelated primary and secondary screens. One of the heatsink screws was flopping around in there right up against the GPU terminals so maybe I just got a bad replacement board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
frankgumeta 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 17,233
