跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
iPhone Logicboard Replacement Part Missing Need Help?
Hi as the title says i'm replacing a iPhone 5 Logicboard, but with the replacement board there's a small part missing. it's like paper thin please see attached pic for reference
As you can see the arrows pointing to the bit missing. So my question is how do i attach this ? As the part is paper thin and its connectors are tiny ? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
TH3ORY, looks like you are pointing to the "cellular Interconnection Flex, cable that broke. You can get it from places like this as well as from here and many other places. It is soldered to the logic board, so you will have to solder it to repair. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
1条评论:
Awesome Thanks, can you please advise what is the best solder kit ? As this part is paper thin.. Thanks
完成的
添加一条评论
添加你的答案
TH3ORY 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 153
