跳转到主内容
DC-In Board cable ripped! Which cable is what?
I wanted to change my heat sink, and I accidentally ripped one of the DC Cable that go to the logic board, while screwing it back in. I already ordered a new one, but this will take a few days.
my question now is, will I break the macbook if I try running it this way? Or does it simply not work at all?
Its one of the lighter grey colored cables.
EDIT:
The grey cable is Ground, right? So does the Magsafe work with only one ground cable?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Wendel Fierce, yes they are both ground. They do connect together in the logic board circuitry. Not sure where you broke the cable, potentially you could solder it. From the schematic it would appear as if your DC-in board should still function and should connect with your Magsafe.
这个答案有帮助吗?
得分 1
4条评论:
Cool, thx for the reply. I am still not sure, if I want to try it though, the new part should arrive wednesday. I will think about it, and maybe even try soldering it.
完成的
BTW its cut between the taped part and the board of the DC-In.
完成的
You could just solder it;-) Thank you for accepting my answer
完成的
I am not very good at soldering, and its rather tiny, so I am not sure. Maybe I just ry it and see how it looks.
完成的
添加一条评论
Personally I would not run the computer with a cable ripped. But then again it is your computer and your choice. I would not risk it unless you still have applecare.
这个答案有帮助吗?
得分 0
1条评论:
Apple care is long long gone. I am leaning towards waiting too. But wanted to check if anybody knows if it could work nevertheless.
完成的
添加一条评论
添加你的答案
Wendel Fierce 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 72
