跳转到主内容
A Nokia E-series smartphone with a physical QWERTY keyboard and Optical Navi Key. Successor to the E71. Released in 2009.
Nokia E72 Motherboard is broken at bottom where it connects charger
Respected Sir,
I have a Nokia E72. And its charging connector part which is at the bottom of motherboard is broken and cut off. Sir, is it possible to fix this issue ?click to see the image
Yours faithfully
Murulimadhav
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Murulimadhav, if it is broken off, you will need a new board. This is a multilayer board and with the part broken off, those circuits are interrupted. There is no other way to fix it. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
2条评论:
ok sir, thanks a lot i got it
完成的
can you tell me where will available the nokia E72 mother hoard .. i find almost all mobile shop in where i am working in ksa and also online but its not available...
完成的
添加一条评论
添加你的答案
Murulimadhav 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 1,115
