跳转到主内容
The repair guide for the Acer Aspire laptop contains steps from disassembly to assembly.
Problem with the screen some strange line in the screen
When I turn on the pc the screen you can see the black stripes, like shades of gray, but if you use the hdmi port on the external display turns on normally.
What could be causing the problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Problem12, sounds like TAB errors on your LCD. Replacing the LCD should fix this.
这个答案有帮助吗?
得分 1
3条评论:
I will try, but is very expensive replace it
完成的
looks like around $50, sorry:-)
完成的
i hope i will find another thing to fix the problem
完成的
添加一条评论
添加你的答案
Problem12 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 1,315
