There is a dark spot in my lcd after it got wet?
My Samsung Brightside went into the lake with me and got all wet. Now I have a dark spot and a bright spot in my LCD. Do I need a new LCD?
Brian, very possible that you have some sort of residue on your LCD. Yes, best is to replace it, as well as replace the battery and clean your logic board with plenty of isopropyl alcohol. Otherwise, you are running the risk of having failure due to corrosion at a later time. Here is the guide for that. Hope this helps, good luck
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 156
