跳转到主内容
This device is T-Mobile's version of the Samsung Galaxy S II. It was released in October of 2011. It was the first Galaxy to include T-Mobile's new expanded 4G network.
Why isn't my phone charging?
I was charging my phone early this morning before my game and before i unplugged it, it shut off and wouldn't turn on. Phone was at about 70% at the time and i still can't get the phone to charge. Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
You can always get the wireless charger if the USB port isn't working. That's what happened with my phone is the USB port got wet and now it won't charge I have to charge it with the wireless charger now. Or I have to blow dry my phone before I charge it or else it won't work. I hope this helps.
完成的
添加一条评论
2个答案
最有帮助的答案
jesseornelas72, check your charger to make sure that it is working. Try a different cable, and check your port for any debris corrosion and bend/broken pins. If all that checks out replace the battery and reevaluate. If none of that works you could be having issues with the power management IC or the charging coil itself. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
Sorry i have ignored the phone brand and model,
This pic is for the Galaxy S 2, and i have marked the Charging dock.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jesseornelas72 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 588
