跳转到主内容
加入维修社区 - 创建账户
HTC Desire 是 HTC 开发的 Desire 系列中的首款智能手机。
Why does the network connection break?
After switching on the phone and entering the pin code the home network cannot be found. After some time the network is found but the connection breaks after about 30 seconds. The connection to the network cannot be restored.
The same problem occurs after a reboot. I have tried another sim card of another network provider - same phenomenom.
What do you think?
Maybe it is an antenna problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
- Look at this manual:
http://www.formymobile.co.uk/desiredisas...
The GSM antenna is the small module at the pic 2. Check and clean carefully the contacts (2x).
- Check at the "Settings" - Network connection. If its - manual, change it to automatic.
- Change the network mode to GSM only.
- You can do a factory reset to resolve the problem, if it's software.
If this not help you, ask a specialist for help.
Regards.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jacccooo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 406
