跳转到主内容
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60 个问题 查看全部
How do I get the internal sd card out?
I have a droid razr that no longer goes past the "red eye" startup screen. I got a new phone, but would like to get my contacts and pictures off the old phone (I didn't realize they weren't on the external SD card). How do I remove the internal memory so I can do this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Peter you describe things as external and internal SD card. Just to clarify, you removed your SD card and the files you were looking for (contacts etc. are not on there). There really is no internal SD card. The RAZR uses a 16GB EMMC Flash Memory IC. You can not access that memory by simple means. You can either try and fix your RAZR so you can access the files needed or have a professional data recovery service do it for you. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Peter 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 625
