跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
freezing, where could the problem be? (have a hypothesis)
So my macbook 4,1 has been freezing now and then for a long time, I've been trying to diagnose the problem for a while (no warranty anymore) and found the following things:
- when it hangs short horizontal bars flash across the screen projected over whatever was showing last
- last 0.1 seconds of sounds or something like that keep repeating or there is some kind of soft ticking/thumping sound (even when no sound was playing)
- There's nothing in the logs before the reboot
- There's no bug in the ram, did a lot of random writes/reads and always came up faultless
- It's not HD related, happens on two different harddisks (one ssd)
- Also happens when running on AC without the battery in
- It's not software related, happens on different OS X installs with only basic very standard software installs, happened also at previous OS X version (use snow leopard)
- It's not external hardware related (happens also with nothing plugged-in)
- It doesn't happen only when using the WiFi (tried cable internet for a while) but maybe it doesn't happen as often (but because of the random factor it's hard to tell)
- Seems to happens more often when using certain software (vlc with certain videos, maybe dependent on the codec?) but not exclusively
- Seems to happen more on hot days but not exclusively. That seems to suggest an overheating problem but:
- Doesn't happen more often when there's high cpu usage
- Also happens when fan speed is at 1800 (lowest) so macbook self doesn't think it's overheating
- Tried using fancontrol to keep the fan speed always at a higher level (double the speed and even just as a test for a short while at the highest), this doesn't prevent the hangs.
- Happens also when using external/bluetooth speakers
So I was thinking maybe the video chip overheating? Could this be a possibility? Or do you have other suggestions? But:
- why didn't keeping the fan speed artificially high help?
- why doesn't it happen during games? granted not very high-end, but starcraft, red alert 2, duke3d, rtcw, sims3)
Is there something more I could do to diagnose?
If it's the video chip overheating how could I remedy it? I was thinking at least just open it up entirely, clean everything, change the cpu cooling paste, but do you think it would be effective especially since cpu doesn't seem the problem? (opening it up entirely seems a bit difficult and risky for a n00b like me, so not something i would do lightly - only replaced harddrive and memory so far)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论:
Please give us the last three figures of you serial number so we know your exact machine and if it conforms to any know issues.
完成的
0p0 ............
完成的
添加一条评论
2个答案
sadly with all your troubleshooting the last thing i can think of is the cpu/gpu is going bad, the issues sound like a bad over clock but seeing as you haven't i would think the chip is just not stable anymore
这个答案有帮助吗?
得分 0
添加一条评论
Well first of all being realistic its nearly impossible to fix such more complicated things if you don't see yourself as some type of technician.
But if you are curious, google Macbook Service Source and check out the document.
It might also help if you could get your hands on Apple Service Diagnostics 3S123.
You would need to take care of that by yourself though ;)
Also remember if you don't maintain a 7 year old device it might gotten pretty dirty inside in terms of dust and debris. So cleaning the thing would be a starting point.
While cleaning you could also check for corrosion etc .
My last guess would be that your device needs some reballing. There are professionals who are rebelling and exchanging gpu for little money (since those gpus aren't that expensive anymore)
这个答案有帮助吗?
得分 0
2条评论:
so the gpu is replacable? it's not on ifixit
完成的
No, not for you.
It'S called reballing. Gpu is desoldered and resoldered. See youtube to get an idea of the process
完成的
添加一条评论
添加你的答案
Freek 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 122
