跳转到主内容
加入维修社区 - 创建账户
Why aren't my MacBook Pro's internal speakers working?
About 3 years ago I spilled milk on my MacBook Pro. It was fine until a few weeks ago when it wouldn't turn on. Genius bar said it would take $800 to repair. Opened it up and scrubbed down all parts with rubbing alcohol and let sit out overnight. Started from logic board with tweezers and I heard the startup chime. Booted up as usual and brought me to login screen. Keyboard was not functioning in certain areas, but the MacBook was otherwise normal. I plugged in a USB keyboard and that worked fine. Sound was working and everything was normal. However, the sound stopped working yesterday. No startup chime or anything, and when I went into system information, it said that no internal speakers or Microphone were present. It does not recognize headphones either. The internals are not corroded so far as I can tell. I've taken out both speakers and rubbed the connections with isopropyl alcohol. What could be wrong with it and how do I fix it?
This is what I see when I go to system information and go to the Audio tab:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
7条评论
Update:I received the keyboard and installed it. Still no sound/usb. I quit the sound driver and restarted the computer. I reset the PRAM and the SMC. I updated all software and I did a complete reinstall of the operating system, to no avail.
完成的
Not sure what could be causing both sound and USB problems.
完成的
I added an image of what happens when I go to system information and click on the audio tab. It knows that it should have internal intel speakers but it says that its value is 0, which I believe means that the Mac doesn't recognize that the speakers are connected.
完成的
Everything else besides sound and USB is working fine.
完成的
UPDATE: I just ran extended testing with Apple Hardware Test and it said "No Trouble Found". I'm not sure, but does that make it a software issue?
完成的
显示更多的2条评论
添加一条评论
2个答案
已选择的解决方案
Recheck your speaker to logic board connections.
这个答案有帮助吗?
得分 1
17条评论:
I rechecked the connections, but there was no change. Could it be a partial failure of the logic board? It would seem odd for that to happen after I cleaned everything with Isopropyl alcohol and left it overnight in front of a fan. I'm not sure what steps to take from here.
完成的
Just cleaned the contacts with Isopropyl alcohol and no change.
完成的
I ordered the keyboard replacement, which should be here Friday, I am wondering if that could be causing the issues.
完成的
Do you see a red light in the audio port?
完成的
No, and I checked with a plastic pick to see if any debris had flipped the audio switch on and it was clean. I plugged in and unplugged a headphone adapter several times and it had no effect.
完成的
显示更多的12条评论
添加一条评论
Hi,
I had the same problem, and I resolved it today. I had checked the speaker connections but they were all in tact. I ordered a brand new logic board and put it in today. When I turned on my computer the speakers worked great.
这个答案有帮助吗?
得分 1
1条评论:
Would it be possible for a USB sound card to fix the issue?
完成的
添加一条评论
添加你的答案
Robert 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 41
总计 5,489
