跳转到主内容
加入维修社区 - 创建账户
2013年9月10日发布的 Apple iPhone 5c 的维修信息和指南。型号:A1532, A1456
Touch screen problems after screen replacement
I have been replacing screens on iphones for quite some time now. The iphone 5c and 5s are a different animal. The last few that I've done have me puzzled. It seems as if once I put them back together, the touch response is all over the place. After a hard reset they work for a while and then when you go to touch an icon, another app may open and not the one you touched. I've swapped out the screen with a different one and it does the same thing. Is there some sort of calibration to do on these new phones? It's getting to the point that I'm going to turn down customers that bring them in to be fixed.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 47
26条评论
Am also having this issue with my LG P895 phone.
由完成的 分享
I am to i have iphone six i was on instagram and then i went to settings to fix it it was glitching or something i had just got my screen fixed last week plz help what do i do
由完成的 分享
If you are trying to fix an unresponsive iPhone 5c, you're not going to succeed in this repair. Save your money. I wish I did.
由完成的 分享
well I have that same problem with my 5s. I just got the screen fixed and its touch response is all wacked up. What do I do???
由完成的 分享
me as well, my 5s screen was just replaced and now the touch response is messed up
由完成的 分享
显示更多的21条评论
添加一条评论
26个答案
已选择的解决方案
I am not a repair man, just a clumsy guy who broke his phone so much that he had to learn how to fix it himself. I'm sure most of you already know about this step, but with the first screen replacement I did I had the same exact problem and it took me three phone breakdowns to figure it out. It is really simple... when you get a new screen, there is typically a red piece of static protection covering the metal back of the screen. There is a little tab that you can grab to remove the protective plastic - if you don't do this before screwing everything back together then the screen will act really strange when you attempt to type. I hope this helps and I don't sound ridiculous!
这个答案有帮助吗?
得分 31
17条评论:
dude this worked for me... thanks for the info...
由完成的 分享
At least I'm not the only dumba## out there lol. I fixed a couple 5s(s) but only with the entire lcd package. A few days ago I ordered a replacement for my girlfriend's son but I accidentally ordered a new screen without the camera, etc., so I had to swap out parts. I didn't just figured the back was red for some reason. I'll have to pull that thing out. Thanks for posting.
由完成的 分享
how do you take apart the phone to see if the plastic is the problem ?
由完成的 分享
The kit I got from iFixit doesn't have any red piece static protection, as you call it.
由完成的 分享
Can I fix this without taking my phone apart?
由完成的 分享
显示更多的12条评论
添加一条评论
I have done many screen replacements, but now I did the 5c for the first time. Touch was not working well after assembly so I reseated the connectors and it was even worse... no touch at all!
I reseated the connectors 4 times in total with no result. I wanted to give up but took one last attempt.
I blew on the connectors to make sure there was no debry on them and then took a cotton swap drenched in 100% alcohol and cleaned the connectors very carefully. After assembly everything worked flawless.
这个答案有帮助吗?
得分 14
8条评论:
will you know if the second hand phone you bought had it screen replaced? please reply
由完成的 分享
Most of the time you can see if its a replacement screen when the connectors have foam pads on top or not.
I hope this answers your question, because I'm not sure what you wanted to know.
由完成的 分享
I had the same problem, replaced the screen and the digitizer was not working at all after mulitple attempts. Read this post, tried it, and now everything works great! thank you!
由完成的 分享
iphone 5c replaced the screen and the digitizer was not working
由完成的 分享
Take apart and remove the protection film from the back of the new screen. Worked for me. I put two screens on before reading that on this site! So greatful
由完成的 分享
显示更多的3条评论
添加一条评论
Guys i have a iphone 5 which i replaced the screen with a cheap aftermarket screen it was done right but i had ghost touches i tried everything to fix it but the answer is simplier than you thought i noticed that when i replaced the screen the screen had a screen protector and the touch was perfect after i removed the screen protector i started getting problems its because the cheap screen do not have oleophobic coating which is a anti-fingerprint coating built into the screen without it the screen will think that the fingerprints are actuall touches so the only think that you have to do is buy a screen protector and thats it ..
这个答案有帮助吗?
得分 12
13条评论:
I bought a fairly cheap 5c screen replacement on Amazon. After about an hour of tinkering with the connections and anything I could think of, but them I put on the screen protector that it came with and it works flawlessly.
由完成的 分享
Im from chile, and i really appreciate your answer, i really fix the iphone
由完成的 分享
Wow thanks! I thought I must have screwed up the repair, but even the crappiest screen protector solves this problem!
由完成的 分享
Thank you so much Omar, you made my day! My iphone 5c screen needed to get fixed & the repair guy tried his best and replaced it 3 times! After 10 minutes or so the touchscreen always did and wrote whatever but not what i wanted! Your tip was the last thing i wanted to try before i get myself another phone.... Cheap protector on - iphone works like a brand new one again! Amazing!
由完成的 分享
Definitely try this before opening up the phone again etc. I had that feeling of dread when the screen started glitching, but after reading this I could see the finger prints, and as soon as the screen was cleaned and the protector added - it was fine. Just make sure the screen really is clean of grease from your fingers etc. using an alcohol wipe prior to fitting the protector.
由完成的 分享
显示更多的8条评论
添加一条评论
OK, I have been reading these comments and while there are some that are correct, there are few or more that are way out there. Guys, as a electronics tech, I have fixed many phones such as this in my time. Yes the cheap screens will fix it most of the time, but there are times when this is not the case. There is no easy fix for this.
First you have to diagnose the problem and the cause and then fix it. Sometimes its as simple as restarting the phone and sometimes the problem is hardware of the phone.
1) Check if the screen responds to any touch at all. If it does work but you get “ghost touch”, problem is likely going to be fixed without replacing the screen. Usually one of the connectors are dirty or not plugged in correctly. Easier fix is to open the iphone, lift the screen from the rest of the case/motherboard and unplug the lcd and other connectors that run from the screen to the board. You could use 99% alcohol and a tooth brush. Scrub the connectors gently and wait a few seconds for the alcohol to evaporate before plugging the connectors in. Usually this will fix the trouble and you will have a perfectly working phone without replacing any parts. IMPORTANT: Do not use 50% or 75% alcohol or acetone. Low grade alcohol is 50% water (and we know what water does to the phones)and the acetone can short out the motherboard or melt the certain parts that are important.
2) If only lower or upper or left or right side of the screen work, chances are very high that you need to replace the screen. You can try the solution above, but it will rarely work.
3) If you had a cracked screen and replaced it with the new one and now touch is not working, chances are that you either did not assemble it correctly or the screen is bad. If your old screen was responding to the touch and the new one doesnt, simply try to install the old one again and see if it still responds to the touch. If it does then the new screen is defective and you should return it. If it doesnt then try the first solution again to see if this will help.
4) Everything is installed correctly but the phone still doesnt work. This can be a bigger issue with the board. There is a tiny little IC(chip) on the phone that controls the touch. There are also few tiny little resistors and capacitors that are connected to the same part of the system. If one of these are bad then your phone is pretty much done. Yes they can be replaced, however finding the person with the skill and equipment to do this it likely near 0. most of the resistors and capacitors are covered with the ceramic coating that is nearly impossible to remove, but it can be done. The best thing technician could do in this case it to reheat the motherboard. This likely will not fix the problem permanently but you may get few extra days, weeks or months before its done for good.
The iphone uses BGA type of chips for all of their phones. These are “ball grid array” chips and they have these tiny little ball of solder that connect to the board. Some may have 10 and some chips have 50-60 or more of them. You can not see them like you would on a SM chip(surface mount). While you are using the phone they have electricity running through them . This makes them heat up and cool down constantly. Problem that occurs is called “Cold solder”. Over the time because of it heating and cooling the solder become brittle and it cracks. Once it cracks it will start to cause problems. This is why sometimes if you press the phone in certain spot it actually starts to work. Well, you are forcing the chip to connect to the board by pressing it in, but once you let go it stops. This sometimes can be fixed by reheating the chip, or to use technical term, “re-flowing”. sometimes it needs so little that the heat may just connect the broken link and it will be fine. Temperature you use to reheat it very important. If you take it to the shop and you see them using one of those industrial heat guns used to strip the paint from home depot, you will probably need a new phone. Temperature is important, but the force of the air flow just as important.
I know most people wont read this whole thing, but there is some useful information I wrote here and everything I wrote applies to almost any phone on market today. All of the phones are basically the same. They all have the same parts, only difference if what those parts are going to look like and their location o the phone, but they all need to have the CPU’s, memory chips, power management chips, lcd or touch controller chips and so on.
这个答案有帮助吗?
得分 7
1条评论:
Thank you for your thoughtful response. I suspect a lot of these after-market screens are made very poorly too.
由完成的 分享
添加一条评论
Ok, so WOW....I solved the touch playing up after several screen replacements on one customers iPhone 5S. After throwing 3 screens in the trash thinking I had a bad batch it was something so RIDICULOUS it's not even funny. The LCD shield plate (where the black soft material is on the right side) had a scratch in it that was exposing the metal underneath. Just on a whim, I covered it with a small piece of Kapton (Polyamide) tape. Voila! The theory is there was static electricity build up causing intermittent touch malfunction. This soft black covering must protect from that. This problem seriously was about to send me to the psych unit! See pics...
这个答案有帮助吗?
得分 4
3条评论:
If this is seriously the answer to this ghost touching madness, I am crowning you a genius. I am seriously on the same boat as you with some of these i5S screens.
由完成的 分享
did it work, Stavros???
由完成的 分享
Solved my problem for a Pixel 3a, thanks!
由完成的 分享
添加一条评论
Have seen this issue in the iPhone 5 but not the 5c
See the part circled in red cover that part both sides with electrical tape it has cured the issue for me
这个答案有帮助吗?
得分 3
4条评论:
The 5c screens don't have that part of the cable.
由完成的 分享
I think this could be my issue.. Ill try to cover it with a tape and comment my result. thanks dude
由完成的 分享
in my case that part was already covered with tapes. but there was a red protective plastic back side of the new display which I didnt remove prior to the installation. so after removing the protective plastic unresponsive/random touch issue fixed as mentioned in 回复: Touch screen problems after screen replacement
由完成的 分享
Isn't that just the backlight connection? It shouldnt effect the touch
由完成的 分享
添加一条评论
Okay Fellows , Here's the trick. When I replace a screen and if not responsive to touch. Simply unplug the battery and plug back in. Easy Fix!! Good Luck,
Ray pairman
这个答案有帮助吗?
得分 3
2条评论:
Like u said, it is a trick, but it does not save the problem unfortunately.
由完成的 分享
Ohhh WOW.
Too Bad in the future we don't have replaceable Batteries.....ehheheheh
由完成的 分享
添加一条评论
Turn the "Auto Brighness" OFF, set Brightness to Medium... this seems to help
这个答案有帮助吗?
得分 3
1条评论:
Have a 5c and tried all suggestions above this post, but nothing worked. Actually the screen worked when connected but not fitted into the case. When I press it down and fixed the black screws at the bottom the screen was messed up again. Tried this (OFF), and it works... Must be a low quality screen, but at least now it works good enough
由完成的 分享
添加一条评论
I had a tech that always having this issue while I was using the same screens I would not. I believe it has to do with bending the flex cable and most importantly where your bending it. Don't left the flex cable bend where it connects to the screen. Before installing it fold the flex cable half way up back onto itself but don't crease it while the bottom of the flex is pressed flat against glass. When you take the old one off look at it and you can see where the bend should be. Try this and If you need a picture let me know.
这个答案有帮助吗?
得分 3
3条评论:
Yes please , take a picture .
由完成的 分享
Yes! This fixed my issue.
由完成的 分享
This fixed my issue with my Pixel 3a as well, thanks!!
由完成的 分享
添加一条评论
I recently replaced an iPhone 5s screen and I had a problem with the screen doing it own thing (typing, selecting apps etc) I found out that the ribbon cable for the back (home) button was folded under the back hot plate of the digitizer causing this problem.
Hope this helps to anyone having the same problem as I did
Aaron. P
这个答案有帮助吗?
得分 2
添加一条评论
Are you touching the ribbon cable connectors excessively? Could be that the oils from your fingers are messing with the digitizer cable. Try and avoid the cable ends. Another possibility is the quality of the screen. Purchase your screens from a quality vendor.
这个答案有帮助吗?
得分 1
2条评论:
No, I try not to touch the cable ends. This has me at my wits end! Do you have any reputable vendors where you get your screens?
由完成的 分享
I cleaned all of the ports and the digitizer started working properly again.
由完成的 分享
添加一条评论
I replaced an iPhone 5c screen with a fairly cheap replacement from Amazon. After putting it all back together and turning it on, the screen was unresponsive/laggy and wasn't registering touches accurately. I opened it back up, disconnected the battery and screen connectors, wiped the back of the front screen with some isopropyl alcohol, and cleaned the connectors with isopropyl alcohol. After reconnecting everything, the issue persisted. I again disconnected the battery and screen and then reconnected them. This time it worked perfectly! I guess I just didn't have the connections properly seated the earlier times.
My suggestion is to clean the connections and keep trying to make sure you have the connections seated properly. Good luck!
这个答案有帮助吗?
得分 1
1条评论:
can i use methylated spirits to clean the connections?
由完成的 分享
添加一条评论
I solved it!
The problem in my case was that I had missed to connect one of the 3 connecters from the screen properly, to the phones mainboard. I bought a really cheap screen from China from ebay, works good!
这个答案有帮助吗?
得分 1
添加一条评论
As per the comment from travishansen1993 it can be quite difficult to get all three of the connectors from the screen assembly to connect properly again after removing./replacig the screen.
The first cable to be connected is the touch sensor, and seems to be the hardest, and my touch sensor wasn’t working at all after replacing the screen. travishansen1993’s comments inspired me to try again, and it took a while to really get that first connector properly attached, (pressing down with the plastic spatula tool) after which it all worked perfectly again. :-)
这个答案有帮助吗?
得分 1
添加一条评论
I had this problem and my screen was broken. It was so unresponsive that is took me 10 tries to enter my password. Gorilla Glue makes a clear tape used for iphone screens cracks (and tents, ect). I got a roll from lowes and it instantly stopped the glitching and protecting my screen from breaking anymore. I don't know why is works, maybe it provides a pressure as the tape is thick. I cut out the home button and the ear speaker and it works amazing! worth a try for anyone with this problem, the tape is $8 that I got at Lowes.
这个答案有帮助吗?
得分 0
添加一条评论
I am the owner of iphone 5s 16gb, and after back case and display replacement i have trouble with screen. I cant click correctly on upper corners. I
1st step i do, is replace from the old display all insulation tape,
2. place insulation tape on every connection (LCD, EARSPEAKER, and 3rd)
2/3. DO NOT turn OFF your phone.
3. dissemble the touch id and open the phone,
4. remove metal bracket (4 screws)
5. disconnect three connectors from display(WHEN IPHONE IS TURNED ON!!!)
6. wait a moment and place the connectors back,
7. unlock your iphone and try.
7/2 if everything works, put bracket back, put back touch id and place it back.
8. that works for me !
这个答案有帮助吗?
得分 0
1条评论:
USE ONLY PLASTIC TOOLS!!!
place 4 scruves at CORRECT POSITIONS!
由完成的 分享
添加一条评论
Hello, sorry for my poor english, but i will try to explain how i fix this problem in a IPHONE 5S. The problem in my phone start wen it fall to the ground, then the touch screen start to go crazy. I try a lot of things to solve this problem because it was imposible to use the phone. First i change the battery, the problem still remain, then i replace the screen, but the problem still there. So i realise that the problem was in the board.
The board have some metalic contacts to make discharge or something like that from static or whatever, when you put a screen those contacts must touch the metalic back of the screen, if those contacts are not touching the metal or are dirty this make the touch go crazy, so i clean those contacts and separated enough to make sure ther will be a good contact then, voila!!!! The screen was perfect again.
这个答案有帮助吗?
得分 0
1条评论:
Qu'est ce que tu veux dire par le contact?
由完成的 分享
添加一条评论
The most likely problem is the connector, it very easily pops out of place despite there is a metal plate to secure the screen related cables. So, what is needed- take the screen off and reseat all the flexcables. The digitizer is the topmost and will be below all the others.
这个答案有帮助吗?
得分 0
添加一条评论
I'm not a repairman either but i have been playing around with the different types of iphones & androids. i had this problem just now with my sons iphone 5c and i tried a few different things. the last thing i did was open it back up for the last time & i noticed that the little chrome tip on the front camera cover was setting on top of flex cable instead of up under it. so i took the 2 screws off this cover & made sure chrome tip was under flex cable instead of on top & i also made sure the black film on top of the vibrator was covering the home chrome of the vibrator when i put screen back together & everything works fine now & screenis fully functional & no lines in it. i hope this helps some1 else.
这个答案有帮助吗?
得分 0
添加一条评论
I seen a great video of a bloke repairing an iPhone 6 Plus by taking out the logic board, flipping it around and placing electricians tape on the reverse of the digitizer connector pins. I have since tried this procedure and it's been 100% successful in repairing intermittent touch issues. Shame there's no such procedure for the iPhone 5c
这个答案有帮助吗?
得分 0
1条评论:
I changed my daughter's cracked iph 5c screen and there were lines@top and it was stuck on the flashing apple logo. I held the home button and other top button for awhile and iTunes logo popped up, still had 3 lines @top. I decided to take apart again & one of the 3flex connectors wasn't on proper and it now works. My new issue is that the touchscreen is not so great, very laggy. I am wondering if the padding on the 3connections may be necessary for one in the middle is missing?
I am tempted to put a small piece of electrical tape on top to cover like other 2.
Would that possibly help. ? Please and thank you
由完成的 分享
添加一条评论
So, I dropped my screen ages ago.
This week I thought, let's fix the crack in my screen myself.
I bought a nice iPhone 6 plus screen replacement, knowing that I had to replace everything.
The fix went fine, until the point that my screen got unresponsive in 2 minutes.
Rebooting didn't work
De-assembled and re-assembled, didn't work.
What did work:
Because of the fall my phone made, one of the unibody's corners was (probably) bend.
De-assembled the screen
I bend the corner back, just so slightly
Reassembled the whole thing.
How do you know you have the same thing?
Assemble the screen, but don't put it back in the phone's unibody.
If it works then, and stops working when you put it in: maybe one of your corners is to heavily bend.
Hope this might help the frustrated ones, just like me.
这个答案有帮助吗?
得分 0
1条评论:
my phone was doing the same after a screen replacement was acting crazy so what i did i removed my phone case and problem solve not sure what to do if either leave my phone without the case or take it back where i got it repair
由完成的 分享
添加一条评论
hello.i have this problem too.my touch screen dont work after lcd replacement.i try all over ways but didnt useful.please help me
这个答案有帮助吗?
得分 0
添加一条评论
It is very possible you purchased an after market LCD. I have done this several times, and they were hit or miss. I suggest looking at the reviews of those retailers you are buying your item from. They are so cheap, I recommend buying two LCDs- with one as a backup. Finally, you may want to use compressed air to clean the “lego” like connectors when you plug them back in. They may be dirty, or not properly connected. It should be a satisfying “snap” when they go together properly. Finally, make sure you aren’t pinching the ribbon as you are putting the item back together. I hope these trouble shooting tips help!
这个答案有帮助吗?
得分 0
添加一条评论
I also encountered the same problem, but I have solved it.
The problem in my case was that I had missed to connect one of the 1 connecters from the screen properly, to the phones mainboard.
And I buy a new touch screen to replace it from vicpac touchscreen
这个答案有帮助吗?
得分 0
添加一条评论
What exactly are you saying MUST be done? You mention the tab on the protective cover - do you mean removing it (protective cover) prior to screwing back together? It may be obvious to you (and others )but I need to be absolutely sure so as not to ruin the expensive parts I can barely afford to pay for. Having to buy another would be very difficult as I live in an EXTREMELY fixed budget and had to beg, borrow, scrape and save to get this screen and my skills of persuasion have been totally tapped out. I am very mechanically inclined and skilled as well as technically adept, but I’m placing all my eggs in one basket here. Could you possible rephrase it in a ‘Screen replacement for dummies’ version by any chance, PLEASE? My bank account will definitely appreciate any assistance and guidance you might provide. Thank you SO much.
这个答案有帮助吗?
得分 0
添加一条评论
All right I know this is an old post I'm going to revive it and add my experiences I don't have the iPhone but I think replacement screens are similar for many different phone model process. I have three phones of the same model they were older phones I got them at a cheap rate. Last December literally within about a week of each other I dropped two of the phones and broke the screens. So I went online and found replacement screens and I found a video showing how to do it. For my model phone it was very straightforward I didn't have to take apart the motherboard I didn't even have to unscrew anything so I attempted to try it myself. I bought five replacement screens from two different vendors and only three of them worked. The other two turned on but when I went to touch the screen it was unresponsive so I sent them back. Those two came from two different vendors but what I noticed on the back of the screen is that they had the exact same sticker on them regarding I guess wherever the factory made it and the production year it was exactly the same so I knew when I saw the second one before I even connected it I had a feeling it was going to have the same error and it did. I'm not exactly sure what the problem was with that but they made a lot of similar model phone for my Galaxy J series with similar names so maybe it wasn't for the exact same phone although the ribbon cable did properly sit into the connection so that's beyond my expertise. I have read some of the comments regarding removing the screen on the back that film on the back of the screen. All of my replacement screens had the same film in this case it was a green color over the gold colored metal foil stuff. I actually decided to leave it on because the touch was still functioning okay and one of the ones when I tried to peel it off the gold medal underneath and at that point the touch-stopped working. Also I noticed one of the screens that I had broken when I took it apart it still had the it had the exact same green foil on top of the back of the metal whereas the other screen did not and to be honest I didn't notice any difference between the two phones for example any typing problem when they were working with the original screens which I think were not even original screens it seems like they were replacement screens and they were working just fine until I dropped the phones and broke them within a week of each other. So I replaced the two screens and now I have an extra screen in case I drop one again but I actually bought a newer model phone it's not brand new but when I bought it it was brand new but a few years old but it has a stronger drop and shock protection so I'm hoping to not have to replace the screen hopefully again for a long long time. I actually called the manufacturer initially but they said my phone was too old and they cannot service it and I called the repair shop the guy quoted me two prices for an original screen and an aftermarket screen and he told me the difference was that the original screen has a slightly better image however there was no guarantee for either one. I was going to have him fix both of my phones but when I saw the video and the guy did it on within a matter of less than 5 minutes without even unscrewing anything it seemed so straightforward I decided to try it myself. I wish I had known about that before because I had originally broken the screen on my original brand new phone and I had it replaced by the manufacturer anyway we can't worry about the past right just look forward to the future but I can't speak for everyone in my experiences with this model phone I've left the green replacement on and so far the film in the back it has not impacted the performance or the typing now I don't usually take my phones outside these are just mostly for surfing the internet at the house and as a backup in case I break my main phone so I can't say for sure if you took it out in the sun or to the beach maybe the heat damage could somehow damage the screen with the extra plastic in the back but for my experience and my use I left it on and it seemed to work just fine I've had it like that going since December now on two different phones and as I said the one phone that I broke already in December it seemed like it already had the replacement screen and I noticed that when I opened it it had the green film on the back and I had had that phone for almost a year and it worked fine until I broke the screen sorry for the rambling on hope somebody finds this useful someday
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ethan Grier 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 196
总计 414,385
