跳转到主内容
加入维修社区 - 创建账户
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
Nintendo 3DS won't power on?
I just replaced the top LCD screen and after putting it back together it wont turn on. When I press the power button all I get is the 3D comes on then goes off quickly. The motherboard seems to be getting power but just wont turn on. HELP!!!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Did you double check your work? Made sure all the cables are properly seated? What made you change the LCD? what happened to your 3DS originally?
完成的
Yes all cables are fully connected. The top LCD screen had to be replaced because the cable was broken.
完成的
添加一条评论
1个答案
已选择的解决方案
Take it to a dark room and turn it on. Watch the screens carefully. See if either of them flash. If the bottom screen flashes then there is probably a problem with the top screen. If the top screen flashes then there is probably a problem with the bottom screen. If no screens flash then there is probably a problem with the speaker ribbons somewhere. This test is not 100% but most of the time it will lead you to the problem.
I hope this helps.
这个答案有帮助吗?
得分 1
1条评论:
Ok thanks I will try this tonight and let you know.
完成的
添加一条评论
添加你的答案
atkinsonkathy37 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 768
