跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Icloud activation lock removal
I bought an iphone and had icloud lock on any ideas of any software to remove the icloud lock as il just have to sell this as faulty.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 22
9条评论
aselachamara - Your solution only steals money from people who have already been victimized it does not work!
完成的
@ Dan, agreed:-)
完成的
what would be a good use for a phone in this situation? Parts?
完成的
Logan, absolutely nothing. Only Apple can help you out. read the answer provided by "Dan"
完成的
I'd presume at the very least you could use it for parts, everything but the logic board that is.
完成的
显示更多的4条评论
添加一条评论
5个答案
已选择的解决方案
There's no way around it you need the username and password
这个答案有帮助吗?
得分 7
2条评论:
Aw thats a shame, thanks
完成的
new logic board will do it
完成的
添加一条评论
Review this Apple TN: iOS: Forgot passcode or device disabled.
In addition review this writeup by the Verge: Apple's iPhone lock stops thieves, but has unintended consequences.
Bottom line here is the phone is bricked ;-{
这个答案有帮助吗?
得分 3
添加一条评论
Do not let Artur to mislead you ...
When your iPhone or iPad is locked it can not be unlocked by anyone, only by Apples Recover Password service!
Someone has already cheated you once when you bought this locked iPhone don't let them deceive you again here too!
这个答案有帮助吗?
得分 2
添加一条评论
The person you bought it from must unlock it. There is no way around.
这个答案有帮助吗?
得分 1
添加一条评论
All you might be able to do is a bypass
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chris Roberts 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 10,737
