跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1169 个问题 查看全部
Where is cellular antenna connector
Trying to figure out why i have no service. Have tried all the usual, reboot, restore, sim check. Have also replaced the dock connector but still wont work.
Works fine when in a really strong signal area.
Thanks in advance, Chris.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
9个答案
已选择的解决方案
it's the little gold prong on top of motherboard next to battery screws. easily bent when removing motherboard for battery replacements etc.
这个答案有帮助吗?
得分 2
添加一条评论
Having a very similar issue and realising that the next place to look is the mainboard to antennae connector, it is just below the battery power connector (towards dock) and appears to connect to the metal ring around the glass of the phone and through to the antennae on located on the back of the dock connector.
Anyone is welcome to add more info or correct me!
Oh and someone seems to have done some soldering on my main board and that connector is missing! if anyone knows what that part is, or how I can fix without one...
这个答案有帮助吗?
得分 1
添加一条评论
Where is the mainboard to antennae connector?
"it's the little gold prong on top of motherboard next to battery screws." (pollytintop)
Can you give me the link to the correct picture? I'm not shure what connector you mean!
Is it the one on the right?
http://guide-images.ifixit.net/igi/vutmf...
Thanks in advance!
Update
I think I know what you mean by "connect to the metal ring around the glass of the phone and through to the antennae on located on the back of the dock connector."
Its next to the "do not remove lable", right?
http://guide-images.ifixit.net/igi/UbuxL...
这个答案有帮助吗?
得分 1
1条评论:
on your first picture you can just see a very small gold pin on top of dock connector... this is the connector from your dock antenna. the other "gold prong" is on the motherboard itself, next to sticker saying do not remove-it makes contact with the silver bezel surrounding the display. sorry but i don't know how to edit your photo to show you exactly what i mean
完成的
添加一条评论
yes, i would like to know that too, since unfortunately there is no repair guide here for loose cellular antenna only for the GPS one, but GPS works fine. i have the same problem since i changed the battery. Seems that i was a little too clumsy but all main connectors (one through six) are fine... i guess.
thanks for helping!
volker
这个答案有帮助吗?
得分 0
添加一条评论
ah, mine is missing, probably where the last owner did as you said! Do you know where I can find this part, or if there is a work around?
这个答案有帮助吗?
得分 0
1条评论:
i asked this question a few days ago and am still waiting for a reply....think i might just take one off another broken motherboard and resolder. i'm sure the part can be made or bought somewhere
完成的
添加一条评论
I fixed this on my iPhone by taking a short piece of earphone cable (thin and flexible), soldering it to the point on the motherboard where that copper piece used to be, and the other end to the little copper aerial piece on the dock connector (on that image it is the little copper pin to the bottom left of the battery power connectors).
Worked for me :)
这个答案有帮助吗?
得分 0
添加一条评论
I found a great tutorial on the net. Maybe it will help you!
"How I recovered my iPhone's lost GSM signal!"
http://www.mauron.net/iphonerepair/
这个答案有帮助吗?
得分 0
2条评论:
Look at page 17 in "iPhone_3G_Disassembly.pdf": http://manuals.4pda.info/Other/Apple_iPh...
完成的
There you'll find the Antenna Location.
完成的
添加一条评论
i have same problem my iphone network works in very strong areas, n no service in another area. i have done all restore,reset etc but don't work.............. what to do
thanks in advance
Ramesh
这个答案有帮助吗?
得分 0
1条评论:
Ramesh, the first thing that you should do is to ask your own question. Right now it appears that you are answering an old question. Nobody will see that you are needing assistance. Click on the link "Ask a question" and give as much information as possible. This way others will see you need help.Good Luck
完成的
添加一条评论
Found this answer at this link. Haven't looked yet to see if this will be repairable or will fix the problem or not. Good Luck.
http://cybermog.wordpress.com/2010/04/29...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 39,476
