Why is ac blowing warm air?
My 2004 Acura MDX is blowing warm air. Sometimes the air will be cold and sometimes not. I haven't checked the freeon levels yet. What could be some other causes?
Josh, bad compressor, bad evaporator, leaking condenser, bad fan etc. So there are quite a few things that can go wrong. Start with the simplest of all, have your refrigerant checked and refilled if necessary.
这个答案有帮助吗?
Josh - just had the same problem. Tried to fix it myself with a "do it yourself" refrigerant charge. No use. Finally took it into the local repair shop and it turned out that the refrigerant tube between the main unit and the rear heater/AC console was "corroded and worn". Anyway - $750 and 2 days later and I had cold air!
这个答案有帮助吗?
test the Clutch relay by swapping it with your headlight relay (same part) No headlights = bad relay.
这个答案有帮助吗?
过去的24小时: 5
过去的7天: 22
过去的30天: 114
总计 17,392
