跳转到主内容
加入维修社区 - 创建账户
A1297 一体成型机身型号:2009 年初、2009 年中、2010 年中、2011 年初及 2011 年末
Macbook won't start up..
I have problem with my mac book.
When i plug in the power adapter, the light on the front starts glowing. But when i press the power key nothing happens. The light stays glowing, and no fan or hard drive is turned on..
the usb ports do get power..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
已选择的解决方案
Have you tried resetting the PMU and PRAM? That often helps get Apple laptops un-stuck.
Also, has this laptop worked until recently? I'd check the RAM, i.e. verify both RAM slots by removing one module and powering it on, removing the other module and powering it on, etc., in order to verify it does not have a bad slot. Also, try known-good RAM, if you have not seen this laptop work with the existing RAM.
It's a near-new machine, so if it's under warranty, that's worth taking advantage of.
这个答案有帮助吗?
得分 1
2条评论:
I've tried the methods for resetting the PMU and PRAM.. but nothing happens as the mac won't boot in any way. I also checked the hardware, disconnected HD, Memory, etc.. but stil that glowing light on the front...
It is under warranty (produced march 2009) but as it was a gift i do not have the invoice so apple won't accept it for service.
由完成的 分享
You don't need the invoice for the repair. They will check the MBP serial number and their database will tell them when it was bought.
由完成的 分享
添加一条评论
最有帮助的答案
Sound a lot like a logic board problem to me. Not very much you can do. ifixit don't currently have this part and it doesn't look like they have a guide either, sorry there's not much else you can do.
这个答案有帮助吗?
得分 1
1条评论:
Agreed, rdkl. Reset the PRAM by holding opt+shift+P+R for a few chimes at start-up, reset the PMU by holding the power button down until the sleep light flashes.
由完成的 分享
添加一条评论
i took it back to apple.
they replaced the logic board and screen under warranty!
thanks for your help!!
这个答案有帮助吗?
得分 1
添加一条评论
this guys where able to help http://www,cheaplaptopsusa1.com
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
fritsmm 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 6
过去 30 天: 30
总计 11,421
