跳转到主内容
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 个问题 查看全部
Power Button Works, but, Will not sleep/wake display
I did a screen replacement and a flex cable replacement on an iPad 2, CDMA.
In short, the power button will turn on and off the iPad, however, pressing the power button will not put the display to sleep or wake it.
I'm assuming that the square circuitry on the flex cable, between the volume buttons and the board connector controls this and could be bad?
Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
Hey Lurch, long time no see, you've been missed.
完成的
thanks mayer. glad to be back.
完成的
John, good to see you back.
完成的
Thanks oldturkey03.
Note to all the folks: if mayer or oldturkey03 answers a question with more than two paragraphs, yup, ya better bookmark it! ;)
完成的
添加一条评论
2个答案
最有帮助的答案
Most likely case is still bad/damaged flex. Post back if two new cables have failed.
jessa
这个答案有帮助吗?
得分 1
2条评论:
Well this is the second flex. The first had a bad volume down, but, I really can't recall if the sleep/wake worked. This second flex, all is well, just wondering if the square circuitry on the flex cable controls the sleep/wake feature.
完成的
Yup, only thing I can do. It's not unusual at least once a year or so to get a bad batch of flex cables, etc. Fast production = higher chances of faulty parts.
完成的
添加一条评论
Can't figure out how to cut iPad off. I assumed I could hold button down and it would cut off. Any advise?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Country Computer Service 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 919
