跳转到主内容
Headphones released in 2011 for use with XBOX 360. They are identified by the model number X12.
Need wire terminations inside the volume control circuit board
The wire between the volume control circuit board and the xbox got pulled out right at the solder joints inside volume control circuit board. I can easily reattach them but don't know the exact sequence to put them back. Looking at the board I can see the following identifications on the terminals. G, V+,M+,R,L.
Wires I have to terminate are a Common Ground, Red, Blue, Green, Green\white stripe
I can tell from what is loft on the solder joint where the Common ground (G) and Red wire (R) land. Just having problems with the other three wires.
Any help would be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I need to see photo of Razer Kraken Pro V2
Volume control circuit board
Same issue wires pulled off - just need to know which wire goes where
If someone can provide photo pls
完成的
添加一条评论
1个答案
已选择的解决方案
Michael Howe , not the greatest of all descriptions, but this is what I have
Green
Red
Green/Copper striped
Blue
Copper
If you need to know where each one connects to on the other end, I can check on that in the morning. Hope this helps, good luck.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Michael Howe 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 13
总计 2,344
