跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot A470 是一款于 2008 年 1 月发布,像素为 710 万的数码卡片相机。
many line images why
The taken image have many line above the image. Can any body help me
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
it would be a good idea to upload a image with that problem.
由完成的 分享
添加一条评论
2个答案
已选择的解决方案
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, Please see this link for further info and a simple fix that may help.
这个答案有帮助吗?
得分 3
添加一条评论
Go to Canons site
They have support pages - the CCD might be under extended warranty.
I had a problem with an A75 taking blurry images and they fixed it for the cost of shipping.
Good Luck
N.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sandeep Hijam 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 17
过去 30 天: 61
总计 11,949
