The touch screen is unresponsive
I keep pushing on the touch screen but nothing moves? What should I do?
The most likely problem is a loose connection on the inside.
Check the connections of the ribbons on the inside of the device. Follow the motherboard removal guide to get to the ribbons.
If this doesn't work, the digitizer may need to be replaced. However, a guide is currently not available for that. To replace the digitizer, one would follow steps similar to the screen replacement guide, but put the components in a new digitizer.
这个答案有帮助吗?
my tablet is in a sleep mode and will not wake no matter what I do.
Tried on and off, reset button and power and up volume button at the same time and nothing changes
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 9,695
4条评论
It will work with A mouse
由 hmrogers01 完成的
the glass is cracked will this keep it from working
由 hmrogers01 完成的
It isnt working not alittle.
由 Richard James 完成的
my screen is cracked and the same thing happening how do I fix this
由 Fantasy Anime Lover 完成的
