跳转到主内容
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
How to replace the volume button on iPhone 3GS
I dropped my iPhone and the volume button fell off. i am looking for a instructions on how to replace it myself
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
最有帮助的答案
In most cases it´s only the thin metal thing that is lost. First check if it´s possible to adjust the volume by pressing a match or small screw driver. If that works the volume button is ok. Buy a new one and then separate it from the plastic part and glue it back on the iPhone. You don´t need to take the iPhone apart.
This worked fine for me.
这个答案有帮助吗?
得分 2
3条评论:
what glue did you use?
完成的
Thanks for the idea fixing the volume button with glue. Easy, simple, best!
As it is very difficult to release the whole volume button, I guess it's impossible to loose the whole button too. Only the "metal" part gets lost! So don't waste your time to replace the plastic thing because it still sticks in.
完成的
I bought a replacement button from ebay and removed the chrome piece from the one I purchased, Applied a dab of loctite and voila fixed :)
完成的
添加一条评论
Hi,
here you will find the information you are looking for.
iPhone 3GS Rear Panel Replacement
In Step 20 you will find the removal of the volume button. And here´s the spare part.
http://www.ifixit.com/iPhone-Parts/iPhon...
这个答案有帮助吗?
得分 1
添加一条评论
I did the same, My volume came off, so I glued it back. So, now it's back on, true. But it's useless as the whole button is glued and I can't move the volume up or down at all (everything is glued and motionless). Can anyone help me please??? :-(
这个答案有帮助吗?
得分 0
1条评论:
rembito, you may just have to replace the volume button. Follow the links given by "Crisb"
完成的
添加一条评论
Wait, where did you guys glue it? Across the entire bottom of the piece? It's a moving button, so I'm worried glue will make it unusable...
这个答案有帮助吗?
得分 0
1条评论:
Mine fell off for the second time now, the first time two months ago I glued it I put too much SuperGlue and one of the sides was hard to press, but it still worked.
Now after all this time it has fallen again, and this time I glued it with a very small drop of superglue right in the middle so that only the "axis" is glued. Making sure the glue only touched the metal part and the rubber, never the "walls" (the case of the phone).
Its better to put very little glue and have it falling once every two months than trying to glue it completely and ruining it like it happened to poor rembito up there.
完成的
添加一条评论
添加你的答案
Welaye Ikeni 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 43,789
