Why the phone's haptic feedback is totally dead
my i9082 isn't responding via haptic feedback ,not even in vibration mode ,checked software related issues but finally concluded that it is a hardware failure.
Vaibhav Sahu, you enter vibration test mode *#0842# and check to see if it works, If it fails, it is possible that you need a new vibration motor. Use this guide to get to your logic board and the motor. Step 3 bottom left shows its location. Still trying to get that part number for it if. Hope this helps, good luck.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,346
Vaibhav Sahu, explain this "isn't responding via haptic feedback" a bit better.
由 oldturkey03 完成的
Vibration is totally off.....not responding at all in any case......checked via different softwares like vibration checker......secret codes for android etc......please help....thanx in advance
由 Vaibhav Sahu 完成的
Just to make sure I understand you correctly. Your phone does not vibrate under any circumstance?
由 oldturkey03 完成的
